Vacuum lines
I've just started having trouble with my 2011 RT. Rough idle, won't automatically downshift (especially into first), and will die when I come to a stop.
In my reading, a possible cause could be the vacuum lines. My husband said he would check them for me, but I can't find where I need to tell him to check. Left side? Right side? Attached to...? I'm basically clueless and he expects me to tell him where to look before he starts taking the tupperware off.
Thanks.
Leslie
Did you check proper oil level?
2012 Spyder RT SE5 Brake pedal mod
Motorbike Professor
There are several vacuum lines on the Spyder. I recommend taking the body panels off both sides. Removing the airbox wouldn't hurt either, in order to do a thorough inspection.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Thanks. We did check the oil. Don't get me started. We just got the spyder back 2 weeks ago from it's 6,000 mile service. Things have been down hill from there. Last night we cut our ride short as it kept acting up. We checked the oil and it is way over full. I guess they just put oil in and didn't check the level? We checked 3 or 4 times, after our ride so I know it was running temp and we let it run then turned it off then checked. The oil level was at the top of the "X" marks on the dipstick, not down at the notch with the "F".
The dealer was closed today, we are gonna call tomorrow. Did I damage anything by riding it with too much oil?
Thanks, we are fixing to start taking panels off and see what we can find.
Leslie
Wow
This is the 3rd 2011 RT that I know about the vacuum lines. Hope yall can find and replace them.
Motorbike Professor
About the only thing the extra oil usually does is force oil to the airbox...especially on the early GS. Since the Spyder was recently serviced, another good possibility was that a vacuum line was merely knocked off (or left disconnected) near the airbox.
-Scotty
Thanks. I am feeling better about this. I've had very little trouble with this bike and sure would hate to think I've damaged it by riding it. We are going to try to get it back in to the dealers and show them the over full oil and go from there.
Leslie
