Page 1 of 3 123 LastLast
Results 1 to 25 of 60
    Mar 2013
    Oregon, USA
    Question Advantages/Disadvantages of Auto or manual Transmissions?
    I am considering buying an RS-S with the Auto/Paddle shifting system and Reverse but as all my experience to date has been with traditional manual shifting clutch systems I am a little nervous about going to this Auto transmission.
    Are there any known issues or problems that pop up with one more often than the other? Anything to watch out for if I test drive one with an Auto?
    Jun 2010
    Austin, TX
    Default Advantages/Disadvantages of Auto or manual Transmissions?
    Quote Originally Posted by MuGGzy View Post
    .....Anything to watch out for if I test drive one with an Auto?
    Yes.....having too much fun! Keep the throttle on while shifting and you will see how easy and smooth it is....
    -Mike
    <Sent using Tapatalk>
    Jun 2009
    Toronto
    The only problem (if you can considerate it a problem) is that there is no clutch.
    While moving, you are always in gear.
    I have a 2012 RSS SE5 and love it!
    Apr 2012
    New Stanton, PA (South Western Pennsylvania)
    While riding last summer with other fellow GS/RS owners, the automatics seemed to run hotter on the temp gauge than the manuals. We couldn't contribute it to any other factors. There were 3 manuals & 2 autos in our group & both automatics ran much hotter, at least 2 bars higher on the gauge.
    May 2012
    sussex, nj and tug hill, ny (west turin)
    it's all a matter of personal preference! I wouldn't be without the sm5! just love the feeling of dropping it and popping it!
    Mar 2013
    N E PA
    I am new to Spyders and the forum. I rode both and felt much more comfortable with the manual, of course I have been riding motorcycles over 40 years and do not plan on getting rid of my regular rides just yet. Feel it will be much easier and more natural when switching back and forth between rides. Of course I prefer a manual shuttle over HST on my tractors too, beginning to sense a pattern here...
    Mar 2013
    N E PA
    Quote Originally Posted by JaymeG33 View Post
    Good to read that as I have some concerns over the heat issue, hope it is the case!
    About the only main difference I see is you will save $1,500 or so if you go with a SM5.
    I have owned four ,s. The first came with the SM5 because that is all that was available. The next three were all SE5's.
    Did not miss the manual shifting. I have only had one glitch with the SE5 in 50,000 plus miles. The shift linkage disconnected on my 2010 RT.
    The way I drive, (conservative, no burn outs, average 5 mph over posted on highways), I did not notice any performance issues, or mileage issues.
    The SE5 is actually fun once you get used to it. Don't miss the SM5 here at all.
    Mar 2011
    Washington, D.C.
    Learned on a SM5, bought an SE5. Love love love the SE5, it's part of what makes a Spyder a Spyder.
    On two wheels, I like having the clutch because there are countless times where it comes in handy to slip the clutch in low-speed maneuvers. On three wheels-- where slow speed maneuvers don't risk dropping the Spyder-- there's no need for that kind of finesse.
    And, as a practical matter, the SE5 shifts *faster* than the SM5, and it doesn't hurt performance, i.e. the advantages you'd see on an MT versus AT with a *car* for example aren't there on the Spyder. If the SM5 was faster or sipped less fuel then it'd be a debate, but as the wise man above just said, the only advantage is that it's cheaper on Day One.
    For the record, I much prefer having a manual transmission on a car than an auto, am partial to having the manual clutch on a bike (although scooters can be fun), but on the Spyder, the SE5 is just a joy to use, and lets me focus completely on the ride (one less hand to cramp, one less foot to fumble with, etc., etc.).
    Apr 2012
    Gilbert, Arizona
    SEs cost more to maintain are more complicated and more reports of various failures. Not a high rate of failures anymore, but something to think about.
    Slowing down in turns is different. SEs shift quick, so they grab real quick if your trying to simulate gently slowing around corners. That takes a bit of getting used to.
    They don't cost as well, if the engine kills either. My kill switch went bad and everything went dead in the middle if a turn through a busy intersection. I pulled in the clutch and rolled through. I know the SEs clutches disengage in certain RPMs too, but I personally prefer having control in emergencies. Can't beet the relaxation of an SE though in traffic.
    Thinks out loud
    Apr 2012
    Talking
    Have the SE 5 and am very happy with it(great to tour with). Also ride a two wheeler and have had zero issues transitioning.
    It's just another choice you get to make and a buck or two you can spend, or save. In the end you'll be happy with your choice. And that's what counts.
    The clutches in the SE 5 trannys don't fully lock up until you get them up to about 4000 rpm... If you loaf along with the clutches slipping; you'll burn them.
    The SM 5 trannys don't have this setup, so it's not an issue with them...
    But I sure do love my ESSIE!
    Mar 2009
    North Hampton, NH
    Love my SM5!! I feel more involved in the overall action of the machine. Like to drive a stick in a car too. Makes me more "in" the process. Tried the SE5 once at a demo at low speeds and did not like it. Felt the Spyder was "driving me" not me it. I suppose I would get used to it. You just have to try both and see which you like.
    Mar 2011
    Washington, D.C.
    Quote Originally Posted by MidLifeCrisis View Post
    The only "extra" cost is ensuring my oil is topped off...
    Mar 2012
    NJ
    We've come to find around here that the SM is simpler, and more forgiving to changes such as pipes, air filters and tuners. The SE is more complex, can be finicky with oil level and electronics, and doesn't always play nice with the same setups that work well on the SM machines.
    The SE is easier to ride for sure and takes less thought. The SM is more old school.
    Personally, I'm a fan of the SM as I grew up on 2 wheels shifting gears. It just feels right to me. My wife would be more comfortable on the SE. But it's really a personal choice. One really isn't significantly better or worse than the other.....
    Clermont, Florida
    I have owned both the manual & the seemi auto and experienced no difference in run temps
    Aug 2012
    CO
    Not having an SE I can't comment. But what is the failsafe mode if say your throttle gets stuck wide open? Not like there's a clutch to pull in, is there? How do you find neutral instantly before you run into something? If you hit the kill switch does the rear tire instantly lock up?
    JLohPhotos
    2008 GS , Millennium Yellow
    Thinks out loud
    Apr 2012
    Talking
    Quote Originally Posted by asp125 View Post
    The engine STOP switch. BRP even suggests it be used to stop the engine before turning the key off. It's a good habit to get into, and may, save your bacon.
    Aug 2012
    CO
    Quote Originally Posted by Jerbear View Post
    Good to know. I have that habit from my two wheeled machines.
    JLohPhotos
    Apr 2012
    Gilbert, Arizona
    Quote Originally Posted by daveinva View Post
    I was referring to the filter and additional labor charges at oil changes and any other adjustment or calibration requirements.
    May 2009
    Connecticut
    I Have both-09SE5 and 2012RT Manual.
    I love having both _Keeps my brain busy- Like the downshifting around corners on the manual- Only thing I could do without on the Manual is the Initial start in 1st gear? Would not win a drag race with it.
    SE5 is Also great and requires little thought so I can "Day Dream" More- Fast as L through the gears BUT have to change 2 filters.
    If somneone GAVE me $1,500 dollars the day I bought the RT I would have got another Auto BUT that being said I,m happy I have the Opportunity to drive Auto one day and Manual the next day!!!!!!!!!
    Sea Doo GTI-SE 90 Jet Ski!!
    Jul 2011
    Mitchell, Ontario, Canada
    Default I have to disagree
    I hate to be nit picky Bob but the published stall speed on the SE5 centrifugal is 3200 +/-200 rpm. So you can be assured it is not slipping at 3400 rpm and above. But 4000 rpm is important because when you up shift at that rpm it will drop 600 to 3400 rpm and there is no margin left.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    It will drop more than that in some gears, so 4,500 is safer. Although we can nit-pic the stall point and shift points, for most owners it is safest just to round off the numbers to the nearest 500.
    Mar 2011
    Washington, D.C.
    Oh, that? How much does that cost when compared to draining and replacing the clutch fluid, both done on two year cycles?
    We're nit-picking by anecdote here.
    Apr 2012
    Gilbert, Arizona
    Not sure. Just posting what the service department told me. Not trying to say mine's better than yours. Just helping the OP decide. If I'm way off base, than I stand corrected. There are others way more experienced and knowledgable than me on this forum who could chime in. There's however no way to deny the SE is more complicated. With complication comes other caveats. That's not to say the SE Isn't an equally good choice and for some the only way they could even ride.
