Help with cell phone emergency #'s
I'm new to the data phones. I've got a galaxy S3. It takes several taps to unlock the phone, tap on the call button, then if I've used contact last, then a tap to get to the dialer.
All the talk of the conceal carry has got me thinking about being prepared for an emergency. So, I'm in an emergency situation, I'm just gonna say, ah, "stop, wait a minute", I've got to unlock my phone, then tap, tap, then tap.
Is there a way to put the 911 contact # on the lock screen so when I swipe on it, it will start dialing? If not on that screen, then on the home screen?
I absolutely love my new phone, but the old flip phone was much faster when needing to dial. just flip it up and hit your speed dial #. Basically one step.
Any thoughts or suggestions to help me be better prepared?
Thanks,
Leslie
You didn't say who your carrier was so I can't give you details because every carrier uses different settings. But in general if you go to the "widgets" section there is usually always a widget that allows you to call a specific number in your contacts from an icon you could put on any screen. So to call 911 on the galaxy 3 you would simply swipe the screen to unlock it and then press a single icon on the home screen. It would take less than 5 seconds.
If you can install apps on your phone it is an great idea to add a I.C.E. app. It is "In Case Of Emergency". It will list medical details specific to you in case EMS or some other medical team would need the info if you were unresponsive.
If you are using a lock screen on an android phone there is usually an "emergency dial" button below the lock screen that bypasses the lock screen, taking you straight to the dealer so you can dial 911
Teddy made me do it
I have the galaxy S3. Here's a shortcut. Swipe to unlock, hit the voice command button at the bottom of the unit, then scream "Call 9-1-1"
JLohPhotos
Interesting
Mind if I ask which service provider you have? I have the S3 from Verizon & have no such voice command button at the bottom of the unit, such as you speak. I do have an on-screen button to tap on another page besides the Home Screen, is this the one you are referring to or does your model have an actual button on the botton of the unit? On the bottom of mine, it has the OPTIONS HOMESCREEN BACK buttons, that's all. Sorry, not trying to Hijack the thread, just curious to know, thanks
AT&T
That button below the screen on the case. http://static.trustedreviews.com/94/...9/s3fronts.jpg hit that twice and voice command comes up (like Siri on iPhones).
I found an easier way just now. Go to your contacts, find your emergency contact's name. Hold your finger on it until the menu comes up. The last choice is "Add shortcut to home". It will automatically create an icon that you drag to your home screen.
JLohPhotos
iPhone
my iPhone 4S with AT&T has an "Emergency Call" button on the password login screen
I'm with AT&T also. I tried this and the menu that comes up doesn't have a "shortcut to home" option. Also, in what reading I have done so far, it seems that on the galaxy S3 that you don't have a "emergency dial" button unless you have a lock code. I don't, I just do the swipe to go to the home screen. I think this is why I don't have the button.
I'm thinking the best option so far is a contact widget. Thanks for this tip. I didn't know I had this but I did find it in the phone.
Thanks. Would rather have this figured out and never need it than need it and can't get to it!
Leslie
Thanks to all of you I think I have found my solution. I did find a widget on my phone and put on a screen then I made my emergency contact with an appropriate picture. This a screen shot of the widget. I'm gonna add a few more contacts, but now to dial this, it is just a 2 tap process and not several.
Lots to learn on this phone!
Thanks again.
Leslie
