Results 1 to 6 of 6
    GOS member (Girls On Spyders)
    Sep 2011
    Billerica, MA
    Default CB Antenna question
    Howdy!
    I snapped off my cb antenna while putting on a travel cover. Does anyone know of a shorter antenna that would work? The cb is the BRP system. Smurfette is a 2010 RT-A. Thank you, and of course ryde safe!
    Registered Users DynamoBT's Avatar
    Mar 2009
    North Hampton, NH
    Apparently there is one at Wally World that will fit.
    Marilyn
    Mar 2008
    Allegan, MI
    I would recommend against using the CB until you get a new antenna. You could damage the CB. I'm not sure the Wally World version will work with the CB. Have the SWR (Standing Wave Ratio) checked by a shop or enthusiast before you attempt to use the WW version. Good idea to check the SWR even after an OEM replacement.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    ...in the pink (Girls On Spyders) flamingobabe's Avatar
    May 2010
    Friendswood, Texas
    the shorter the antenna the less reception...4 foot antenna works best...go to a cb shop..as Scotty said you could mess up the cb if you try and use it with no antenna
    #IamARyder #RideASpyder #CanAmSpyder
    Jul 2011
    columbus, georgia
    I broke my CB antenna while in a hurry to get my cover on because of storm approaching while traveling in South Dakota. Replaced with a J+M replacement antenna that is pre-tuned with install kit for the spyder.
    Giving me better coverage.
    Jerry
    Mar 2008
    Allegan, MI
    Quote Originally Posted by jeromeb View Post
    Jerry
    Good advice!
    -Scotty
