Results 1 to 8 of 8
    Registered Users Araņa805's Avatar
    Feb 2013
    Oxnard, CA
    Default Stupid ? on 12v charger
    I looked everywhere in my front cargo for the 12v charger on my 2012 rt limited. Is there such a thing?
    i know the one on the trunk... Is there one on the front or do I need to install it?
    Very Active Member Wiredux's Avatar
    Aug 2012
    Jacksonville, NC
    That you need to install.
    Feb 2013
    Oxnard, CA
    Quote Originally Posted by NCSpyderRT View Post
    Thanks ..... Was going nuts looking for it.... Will get it done then
    Active Member ornerydog7's Avatar
    Sep 2011
    Allen, TX
    Quote Originally Posted by Araņa805 View Post
    2012 RT Limited
    it has a power outlet power cable that is tie wrapped to the frame behind the frunk (check along the frame of the left front tire) that has power to it and is ready to plug into the outlet. You have to look hard, but I think it is there, it is there on the 2011's. You may also a search , type in frunk power. Good luck!!
    2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
    Aug 2012
    Jacksonville, NC
    I stand corrected.
    Very Active Member TexasSpyder's Avatar
    Apr 2012
    USA Andrews, TX
    If I am not mistaken I read the front one is factory wired to be hot with the key on only which wouldn't work for a charger unless you run your own wires instead of using the existing wires.
    J. D.
    2016 F3T Magnesium Metalic : Smooth Spyder Dual Backrest, Lamonster LED Head lights and Fog lights
    Mar 2008
    Allegan, MI
    Quote Originally Posted by 20Limited12 View Post
    J. D.
    The optional RS circuit works only with the key on, although it can be wired to be hot continuously if you switch the harness and fuse. The RT rear outlet and front harness are hot all the time. The 2013 outlets can be operated either way, by switching the fuse.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Bryant, Arkansas
    Another day, another lesson learned. Please dont give me any more info today, my brain is tired already.
    Thanks for the good info.
    Cruzr Joe
