Results 1 to 20 of 20
    North Texas
    Default My first error code, Seat switch.
    Ok I got my first error code on my STS only 24 hrs out of dealer, the fun begins.
    I got a " Passenger seat switch defective " error code with corresponding VSS indicator light. It went away after a shut down and restart but only let it restart for a couple of minutes. I got a feeling it will be back again.
    I have searched here and found others with the same problem and suggestions but no real follow up if and how it was fixed or not.
    Has any had this and know the cause and fix for it? I will take it back to dealer anyway to get my heated grips installed just wondering if their is a simple thing I can do now.
    Thanks
    Very Active Member Arr MiHardies's Avatar
    Nov 2011
    Las Vegas, NV
    Lift up your seat. you wil see a cable running from it connecting it to the machine. make sure it is plugged in securely.
    President - Spyder Ryder of America - Mojave Desert Chapter
    National Web Master - Spyder Ryder of America
    Default Seat switch..!!
    disconnect and re-connect check that cable was not pinched or damaged.
    ​2012 RS sm5
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    When I had my corbin seat installed on my 2010 RT-S, they didn't either hook up the connector or they some how installed the sensor upside down. Bottom line is that it messed things up. It was an easy fix.
    Chris
    Registered Users Captain Fin's Avatar
    Aug 2012
    Key Largo, Florida
    Default Error code
    My first error code was 30 miles from the dealer. I had my foot lightly on the brake while under way. Stopped and took the key out and all was well.
    Don't just dream the dream! Live the dream! Sent from my coconut using tap-a-nut. Spyderlovers Southern-Most Member.
    They must have not hooked up the passenger ejector seat!
    Seriously; Pop the seat, and make sure that the wiring that hooks up into it toward the rear is securely plugged-in!
    Nov 2012
    North Las Vegas, NV
    Smile
    My first "problem" was on the way home from the dealer after purchasing my spyder. Orange screen with BRAKE FAILURE! Since I had stopped OK I continued on home seeing this screen a few more times. When I looked for answers on this site, the advise was to check the brake fluid. After adding what seemed like a very small amount of fluid no more problem. Sure is scary though two blocks into first ride.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    North Texas
    Took a look did not see any damage. I took off connector and reinserted heard the click but same issue comes up. Does not seem to effect anything I can see, took a 300 mile round trip all else seems well.. Annoying
    This is definitely a "Call, and see your dealer" episode.
    Please let us know what they find; Good Luck!
    Mar 2008
    Allegan, MI
    See your dealer, the switch is probably defective. Sorry for the hiccup.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    North Texas
    Most definitely will be taking it in this week already getting close to my 600 mile check.
    Thanks
    More good reasons above as to why the dealer should take the out for a good test drive to make sure that it was prepped properly and that none of the annoying lights and warnings pop up on the ride home.
    The is to technical of a machine to just give it a cursory look and send it down the road. I believe a lot of "glitch" issues would be solved, if a good test ride were part of the procedure in every delivery instance.
    In the absence of a good test drive by the dealer, I also recommend the new owner put on 20-50 miles in a radius of about five miles of the dealer. If something "pops up", then the dealer gets it back right away.
    North Texas
    Agree,
    My dealer put 5 mile test drive on it and I did about 10 miles before I left the area thought all seem well. But my problem showed up at about 100+ miles I should be able to make it back to dealer by Friday or so I'm close to my 600mile and will take care of that also.
    If you see that error code pop up again; note when it occurs, and under what circumstances. Give your dealer whatever list you end up developing.
    (It couldn't hurt! )
    North Texas
    Oh it shows up all the time, no special circumstances can be flat and straight, just have to wait a while after start up and maybe 10 miles or so and it will pop up again.
    North Texas
    Took it to the dealer today and they confirmed that the passenger seat switch was bad and it was replaced. Also did 600mile check all else was well. Took a nice long trip home no errors 60+ miles, so far so good happy, happy.
    Mar 2008
    Allegan, MI
    -Scotty
    Now you can let you passenger know that the ejector seat has been fixed!
    Aug 2012
    Semmes, Alabama .
    Only Bob!
    It's what I do bestest...
