Results 1 to 7 of 7
    Jan 2013
    Bradenton, FL.
    Default 2013 ST-S exhaust
    Do you think the TB exhaust for an RT will fit the 2013 ST-S
    Dec 2012
    Greece
    No dif hook up
    Are you sure? For 2013; all of the Spyders will be using the same engine configuration.
    Time to check the accessories catalog and see if the various Akrapovic systems have different part numbers...
    Dec 2012
    Greece
    Dif set up for sts and rts hangers and bends to fit. But can be done if you work it out slowly when putting it on..? Took tape to bouth and the bends some what dif, shape to dif on the out side of each of them? Just have to look at them up close and tape them and you will see the dif hook points for them.
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    I just installed a 2 Bros. Vale can I had on my ST. using the RT midpipe. The hangers are more forward than the RS hangers, the strap will go around the can at the very front of the can rather than 1/3 back. The can will also be moved outwards an inch or so more. I ended up cutting 1.5" off the front of the pipe where it clamps to the Cat and reflaring the opening slightly to fit the Cat. This moved the pipe inward and forward and now looks good. 2 bros. said they will have a setup for the ST in a month or so. Just the 2012 RT midpipe list for $129, I would wait for the correct pipe if you already have the can, I just couldn't wait.
    Jan 2013
    Bradenton, FL.
    Default Great news
    Thanks for the feedback to all! This board is a great resource and truly a piece of mind as this is our first spyder!
    Mar 2008
    homestead, FL>
    Here are some pic's of the reworked RT midpipe. I will have to make a heat guard to cover the mounts, I may ceramic coat everything black.DSC00220.jpgDSC00221.jpgDSC00218.jpgDSC00219.jpg
