Shock Setting Advice
What should I have the dealers set the shocks at on my ST-S? I'm about 230 lbs.
I saw the thread that suggested 5 for front setting but didn't know if that applied also to the 2013s.
Any insight is appreciated, thanks!
I thought that the 2013 models no longer have adjustable front shocks. I do not know about the rears.
shocks
if it is anything like the previous models BRP has put out in the owners manual there is a chart by weight for the shocks to start with
Motorbike Professor
They are not adjustable, as far as I can see.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
No adjustments, and none should be needed with the new suspension setup.
SpyderLovers Sponsor
There is no adjustment and the springs are very weak, I installed 2010 RT shocks and the difference in handling was amazing. I almost didn't do it as I thought they were now shorter, the stock shocks were compressed over 1" from just the weight of the spyder. The rear shocks have a progressive spring rate and feel plenty firm.
The rear suspension actually carries most of the payload...
They've set the front-end up so that it's less sensitive to inputs such as weight and weight transfer.
It's simpler for them, and simpler for us.
