Results 1 to 9 of 9
Thread: DPS LIGHT
    Feb 2012
    frisco city al
    Default DPS LIGHT
    When I parked my 2010 RTa/cSE-5 6 weeks ago no lights or codes Iv'e been pushing it around the shop from place to place I started it this morning and got check DPS and a red eng light on the dash any Ideas I can't remember how to make it show the code with the mode button Thanks Neel
    Invalid Emails
    El Reno, Oklahoma
    Quote Originally Posted by Rattigan_Roger View Post
    If it is an RT
    MODE - SET - TURNSIGNAL
    I had the same issue with my RS.. And according to can am.. There is a recall on the 2010-2012 DPS unit.. May need to check that out just in case
    neelbert,
    Could this be a case of the battery being a bit low from the last six weeks of inactivity?
    Can you throw it on a charger and see if that helps?
    Good Luck!
    Bob's suggestion about charging the battery is a good one. I would recommend trying that first.
    Feb 2012
    frisco city al
    Two codes PD551 and PD552 where do I find what they mead THANKS NEEL
    Feb 2012
    frisco city al
    Quote Originally Posted by neelbert View Post
    I've got a battery tender on It
    Mar 2008
    Allegan, MI
    P0551 = Torque sensor open
    P0552 = Torque sensor short to ground
    The remedy for either is to replace the DPS...but I would charge the battery first and see if they go away. A low battery can cause all kinds of faults.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Well then, time will tell...
    Feb 2012
    frisco city al
    I paid for a extended warranty in Nov. It may be fixing to pay for itself
