back tire air pressure
Hello all,
I hope things are going well as you walk or ride into 2013. I posted not to long ago about finding the tire stem on the back tire to be in a hard to reach spot. Well when I can reach the stem to check the pressure it is normally below the recommended PSI. Is it normal to have to put air in the back tire often? The front tires keep the PSI really well. Oh I am a big guy...but not close to the 440lb RS weight limit
In a word ,Yes. Most tires for motorcycle use tend to lose some air in a relatively short time ,
Where as car tires don't.
Just to add the awkward location of the valve, Some times will cause some air loss while checking.
Originally Posted by Laila's Dad
Hello all,
Have you tried nitrogen in your tires, we have in all 3 and haven't had any issues. Nitrogen doesn't expand as much in hot weather & doesn't shrink in cold weather as bad as air. Our dealer has offered to put it in for free, might try your dealer.
Motorbike Professor
Actually, all our Spyders have held air well...far better than the motorcycles. This is probably due to the larger tire volume.
If you are losing a few pounds every week or two, and the storage temperature is not fluctuating drastically (or you lose air even when the temperature rises), something may be wrong. The back tire should change pressure any more rapidly than the fronts. The first thing to do is check for leaks at the valve core.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Re: back tire air pressure
For real? Like nitrous?
Sent from my SPH-D710 using Tapatalk 2
2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
http://www.tirerack.com/tires/tirete...S|b|6698650813&
Nitrogen in tires, yes.
well i guess i will have to monitor the tires longer. i got the spyder in October and although I am in Tejas the temperture has steadily gotten lower each month(in the 40's now).Plus I didn't get my M endorsement right away so i didnt start putting real miles on the spyder til recently. I am getting close to the 600 mile check up so I will have the dealer take a look then.
is the dealer the only place to get the Nitrogen? is it easily obtained?
Motorbike Professor
Air is 78% nitrogen, so I'd say it's pretty easy.
-Scotty
Nitrogen....
Guys/Gals,
Putting nitrogen in your tires is a farce. Air contains 78% nitrogen already and about 21% oxygen. You would have to be able to completely empty all the air out of your tires and add pure nitrogen in. This would take two valves on your wheel to do. If you tried to vacuum the air out of your tires they would pop off the rim before you could get sufficient air out to make a difference. This was a ploy by the car companies to get more of your money when you purchased a car. Don't fall for this. Now garages are offering this but I have never seen any real proof that adding nitrogen helps any.
Laila's Dad, you may have a leak around the rim or there is a leak from your valve. Fix that and you won't be leaking any air out.
Brian
Hi there Some car tires delars here in New Zealand have Nitrogen run's cool keeps tires same psi and tires last longer to , there words
I don't run it but my psi is 29 in the rear and in the front it is 19 psi
Originally Posted by bscrive
Guys/Gals,
Brian
I dunno about that. I'm not an expert, but most of the teams in the race series I'm the starter for run nitrogen in their tires to keep the pressure more stable. The teams swear by it.
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
Motorbike Professor
In a racing tire, where 1/4 pound can make a difference, it can be somewhat helpful to run nitrogen. Remember that races only last a short while, and the only variation they are chasing is due to tire heating, rather than a wide range of climatic changes. Using 100% nitrogen makes things a bit more predictable...and nitrogen from tanks is dry, to add another constant. For street driving the use of 100% nitrogen is of minimal value, there are too many other variables. It is strictly a money maker, and any benefits are more perceived than actually realized.
-Scotty
2012 RT Limited. Flag graphics, Lower vader wings LEDs, Lower day runner LEDs, Uper turn signal LEDs, Tip LEDs, Finder strip LEDs, Mud flap running an turn LEDs, Inside morrirs turn LEDs, 3-4 brake LEDs, Blue LEDs top under dash, Cup hollders, Large foot rest, HWY foot rest, K&N air flter, GloRyders with remote, Elka shocks 1+R, Soomthspyder, GoPro Hero3, BRP hitch, Diamond shadow trailer.
"Nitrous" is nitrous oxide or laughing gas, you could inflate your tires with it if you wanted to laugh at getting a puncture.
Here is Jay Leno speaking about the benefits of inflating tires with nitrogen:
http://www.getnitrogen.org/n2study/video/leno.html
2011 RT-S SE5, Acumen Tempest Cat-1 Alarm, SmoothSpyder Belt Tensioner,
Autocom Super Pro Auto, Garmin Zumo 550 BT, 10amp Socket, Front Fender LED's,
Grip Puppies, Spyderpop Belt Guard, Nautilus Horn, Shortee Antenna, BajaRon's Swaybar,
Cree LED Day Running Lights.
Alignment Specialist
I go 17 and 27...many have found that too much more pressure will lead to uneven tire wear (too little tread on the ground). There have been many talks about this over the last several years...you want more tire on the road for more traction, unless you're in the snow...more pressure is like a high heel vs. a sneaker...yeah, more psi, literally, but more wear to the center of the tire...and this is not the way the tire was built...only good if in snow...and most of us are not riding in snow all that much.
Everything within reason...BRP recommendations seem very low but they know what they are doing. I feel like my bike handles well and is comfortable at 17 and 27.
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
Well i guess Nitrous could be right, The thought of of using Nitrogen in non racing tires does make me,
Want to Laugh.
If you're putting Nitrous in your tires, you're doing it wrong. NOS goes in your intakes for the fastest drag race times.
JLohPhotos
Hello all,
No body has talked about the fact that a tubess tire has to seat in to the bead of the rim I've had new tires mounted that I didn't put on right away and after a few months they were low on air some more than others put them on and start using them and they hold air fine tires need to heat up and soften to seat into the wheel so they need to get used and have a few longer trips to seat
2 happy happy spyders
I agree...
it's free and it's everywhere! says Jay! whee! seriously if you don't have 600 mi on your bike in 3 mos, you're not driving it enough! But thanks everyone for this wealth of information! you guys are the font of knowledge of all things! and Happy New Year!
You are right, I know of folks who had 600 miles in one month but we all go at our own pace. Plus I didn't get my M endorsement til close to the end of November(before Thanksgiving though). I think the big difference between me and many other spyder riders is that the spyder is a secondary, mainly for fun, vehicle so with my wife and now with my daughter I have to always take my truck or our SUV if she/ they are with me which is more often than not. That's why I go by Laila's dad. If I was on my on schedule I would have went with "sergeant G" or something I thought was cool, lol.
Thanks for some truth from the other side of the airhose!
I agree that the nitrogen is a Joke in passenger cars. First of all, anyone who has worked in the Refrigeration Industry knows that nitrogen is very cheap and every AC&R supply has cyclinders of it. It is used to help purge non-condensibles (air and moisture) from closed systems before hooking up the vacuum pump. The new car dealers use it as a con to get extra money on the window sticker. Period. I do a lot of driving in my job and go through a new car every two to three years and the last two I've had did have nitrogen in the tires. I told the dealers that I wouldn't pay the $199.00 extra for it that it is a joke. My experience with it is it is true that nitrogen does maintain a more constant pressure than air but only by a fraction. My present car has the tire pressure moniters on each tire and the pressure will fluctuate by at least two pounds. Why? My guess is the tire compound will expand or contract with temperature thus the nitrogen has more or less room resulting in a pressure change. I can understand maybe one bad moniter but all four tires stay within a half a pound ranging from 36 to 38.5 from cold to warm. This is something I have kept track of for thousands of miles. Whenever I have had to add pressure due to a flat or normal leakage I add air,. not nitrogen.
Didn't mean to get long winded on this but I hate to see people get "ripped off" at the dealers.
Happy Spyderlovers
