Results 1 to 12 of 12
    May 2011
    kansas
    Default Air wing trick for those of us who ride even when its zero out
    If you own air wings (I have an RT but I think this will work on a RS) you may know they are great for helping keep the cold wind from blowing on you in the winter. However there is a large gap between the bike and the air wing. During the summer its not a big deal but in the winter you can really feel the air entering into that gap. The trick is to switch out the right and left top air wing, you will not be able to open and close them till you rotate them back but in the winter who wants them open? Anyway by switching the two sides you reduce the gap by about 75% and drops the cold wind down to almost nothing. Give it a try.
    Very Active Member SpyderLady's Avatar
    Sep 2009
    Moscow Mills, MO
    Could you pease post a picture, I am having trouble visualizing the suggestion. Thank you.
    SpyderLady
    Registered Users acinpcola's Avatar
    May 2011
    Cantonment, FL
    Of course you could always buy the gap filler piece by airwing also...I enjoy ryding in my bubble of warmth
    AC
    2014 RT S SE-6 Cognac, 2014 Indian Chieftain. Retired Navy Chief
    Quote Originally Posted by SpyderLady View Post
    I'm having trouble getting my feeble mind wrapped around it...
    May 2011
    Cantonment, FL
    attached are pics of my wings
    Very Active Member DocRags's Avatar
    Jun 2011
    Milton, FL
    Quote Originally Posted by acinpcola View Post
    I think everyone is wanting kbfk to post pictures, AC, but thanks for posting a picture of your wings. Both sides of the airwings look the same to us so swapping left for right doesn't look like it would change anything.
    2008 GS Phantom, 2012 RT Limited
    Cheryl Reinhart Ragsdale
    May 2011
    kansas
    Default Sorry Holiday or I would have responded earlier
    I was referring to what air wings call the inner panels. You can see them in the photos acinpola posted (thank you). They are the panels that are the top and closes to the spyder. By swamping the inner panels during winter it blocks even more air though you can no longer rotate the panels when you swamp the left and right inner panels. Work wonders when its below freezing.
    May 2011
    kansas
    Default Here are the pics
    Here are the pics, I hope this makes what I'm saying clearer. Note the inner panel is in front of the mounting brackets. Normally they are behind the mounting bracket and will swivel much like the regular top panel also show in the photo. Sorry my RT is dirty but its been snowing and I ride all year. (yes. I stay home when its actually snowing, but when it stops ....)
    Sep 2009
    Moscow Mills, MO
    Kbfk. I cannot pull your pictures up. Please try to repost again. Thanks
    SpyderLady
    May 2011
    kansas
    Default Adding the photos in a different way
    NOW it is clear to us! Thanks!!
