Results 1 to 24 of 24
    Sep 2012
    fort lawn south carolina
    Default cheaply made spyder
    I love my spyder but am anoyed the body connections was so so cheaply made most are push pin RUBBER or torx screw into Plastic come on BRP we spend 25k on a bike and you make it to be light but cheaply made of rubber connectors I rather of paid another $500 and have a quality composed body then one that the screws dont stay tight or even tighten up my new machine less then 1000 miles on it and already the body pannels screws are comming loose try a little better next time
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    What body panel screws????? I haven't found any screw that screws into plastic. Each screw has has a nut-type connection to make sure it can be tightened and not strip.
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Registered Users Campverdefela's Avatar
    Aug 2009
    Camp Verde, Az.
    I used to think the same thing, but I have softened my opinion a bit realizing you really got a lot for your money [tech, design, safety] and in my three years living with the RS, I haven't had any problems with the fasteners or any panel.
    Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
    Mar 2008
    Allegan, MI
    The Torx screws don't go into plastic, they screw into metal speed nut clips that are installed in the plastic.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    May 2009
    Connecticut
    If you have a RT you will want to put a Piece of Gorilla tape on the Speed metal clip in the middle of the Side middle panel because More than once I have tightened a few screws and then the metal clip on that one falls off to the side and you Start All over!!
    I won,t be taking the side panels off the RT half as much as I do the GS because DAT mirror Does Not have an infinite number of Take Offs?
    Sea Doo GTI-SE 90 Jet Ski!!
    Registered Users MLavore's Avatar
    Sep 2012
    Virginia
    Default hehe
    Quote Originally Posted by Campverdefela View Post
    Three years living with the RS, you make it sound like you're married or sleep in the same bed
    Knowledge is knowing that a tomato is a fruit, but wisdom is knowing not to put it in a fruit salad.
    Aug 2009
    Camp Verde, Az.
    Quote Originally Posted by MLavore View Post
    Well she does have her own room [half the garage] and the wife doesn't seem to mind, so I just may be a bigamist
    I have had no problems with the body panels coming off any of my four ,s. My dealer had a panel drop off his 2010 RT a couple times though.
    Doru the Destroyer-Spyder Photo Investigator docdoru's Avatar
    May 2008
    Clearwater, FL
    I used to think the same thing, but I have softened my opinion a bit realizing you really got a lot for your money [tech, design, safety] and...
    ...airplane tickets!?!
    2013 "Silver Dream" GG Taurus
    2008 "Silver Dream" Spyder RS
    Einstein's theory of drag racing: Time and Speed are Relative.
    Shut up and Race!
    Jun 2011
    lincoln de
    Default spyder in the shop
    Had over flowing through the coolant tank dealer had it 5 weeks new radiator new water pump new gaskets.They drove it for a hour was fine I was driving home had to pass a car and yes its back they never fixed it they never kicked it in the butt they like sunday drivers 65 mphor better is when it overflows not happy with the service I get at my dealer Talbot power sports. Wasn t out of the shop for 45 mins
    Invalid Emails
    Dec 2010
    Augusta Georgia
    WOW, that was tough to read!
    I think that's been stuffed in here in maybe three places now too...
    Tough read; no matter where you put it!
    Registered Users the nicko's Avatar
    Jul 2009
    sweden Luleå
    spyderpoop
    use looktight on screw all the time ,same problems with all bike in the world and brand , calls vibrations
    great feed back with pictures
    Mar 2008
    Allegan, MI
    Quote Originally Posted by the nicko View Post
    spyderpoop
    Never use Loctite on a fastener that is screwed into, passes through, or mounts plastic to the threaded surface below. The plastic will craze, crack, and can fail if any Loctiote touches the plastic or squeezes out. Loctite makes plastics very brittle, and shrinks them.
    -Scotty
    Sep 2012
    Rainbow City, AL
    Quote Originally Posted by baldeagle55 View Post
    All that from a body panel screw ?
    Active Member crossbowme's Avatar
    Jun 2012
    South China, Maine
    I have had almost a dozen new bikes and god only knows how many used ones. BRP is no better or worse than any of the others. When they're out of heavy metal and built like a tank they're designed by some idiot in a vacumn. I have been flying for almost 50 years and BRP's are built far better than many aircraft I can tell you! That is where all the bikes are going nowadays - highly engineered and light material. It's like an airplane and YOU have to learn how to service it properly. With aircraft, if you don't learn the right way, you die. Real simple!
    2021 Can Am Spyder Sea-to-Sky
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    did anyone ever take the tupperware off a gold wing,worse than a spyder any day
    washington state
    TLC is whatneeds
    2012 Spyder RT SE5 Brake pedal mod
    Mar 2008
    Allegan, MI
    From my conversations with the OP, the fasteners in question were the security screws on an RT. The dealer apparently loosened them at the last service. Hopefully the problem can be corrected soon, but maybe not by the obviously uninformed technician that caused the problem in the first place.
    -Scotty
    Very Active Member flaggerphil's Avatar
    Mar 2012
    Florida Space Coast
    In some cases, punctuation would also do wonders...
    Phil
    I may be old, but I got to see all the cool bands.
    2011 Spyder RT-AC
    Very Active Member daveinva's Avatar
    Mar 2011
    Washington, D.C.
    I will say this about the screw/panel setup... the next Spyder I buy, I'm *most definitely* swapping out all the screws for Dzus fasteners the very first day home.
    When I bought my RS, I remember reading folks talking about using Dzus fasteners. I figured I wouldn't need them, how many times would I have to take the panels off, really?
    I've since lost track of how many times I've had to take panels off with mods/tweaks/cleaning/searching for items lost deep within. It's definitely often enough that putting on Dzus first thing would have more than made up for a zillion torx ratchet-hunting expeditions.
    Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
    Aug 2012
    CO
    The Spyder is overbuilt. Most of the time it's a good thing, until you need to pull panels off and service them. Then you wish it were like other tupperware bikes with more quick release push pin fasteners.
    JLohPhotos
    2008 GS , Millennium Yellow
    Mar 2010
    Pennsylvania
    Default Its the Mirrors
    Taking the plastic off has not been an issue, but every time I take the mirrors off, I wonder if the plastic will make it. There must be a better way of attaching the mirrors. They are getting looser and looser, in spite of the tension springs being tightened. The other issue is the plastic flexing each time the panels are removed. Obviously these panels are made so they can be removed, but I doubt they are made to come on and off as many times as they do.
    The Spyder seems to be a well made, and possibly over engineered machine, but I do think some additional thought might have gone into the removal of panels etc.
    Now if the could add two more gears so it revved a bit slower on the highway, and got a bit better gas mileage I'd be happy.
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default CHEAP
    CHEAP...???
    I just did my 2nd OEM muffler MOD... 1 for my RS and now one for the RT... i challenge you to take one of these mufflers apart, and still tell me that BRP makes cheap stuff... these mufflers are BULLET PROOF...
    ROCK ON BRP....
