Results 1 to 14 of 14
    Franklin, NC
    Default RT rear turn signal bulbs
    I need to replace one of the rear turn signal bulbs. I bought an 1156, but the 2 pins that lock it in place are different. The 1156 pins are 180 degrees apart, the stock bulbs are less than 180 degrees.
    May 2009
    Connecticut
    http://www.spyderlovers.com/forums/s...rn+signal+bulb
    I searched and found this- Maybe it will help?
    Sea Doo GTI-SE 90 Jet Ski!!
    Franklin, NC
    Quote Originally Posted by Sarge707 View Post
    Thanks, that is what I was looking for.
    Jul 2011
    PA
    Quote Originally Posted by pickelhead View Post
    The 1156 has a base designated as BA15S which includes pins that are 180 degrees apart. You need a bulb with a base designation of BAU15S which includes pins that are offset not opposite each other. Both bulbs have an S8 shape so they look similar but the pins are not.
    RT and Gold Wing States & Provinces
    I've got to crawl back into the coffee cup for a second dip before I can even begin to figure any of that explanation out...
    But thanks for posting it!!
    Jul 2011
    PA
    My Pleasure!
    Oh! I sure don't mean to make anybody think that what you were saying wasn't right; I'm just not very good at technical stuff and have to get my paws on things before the parts of the puzzle start making sense...
    Franklin, NC
    The cost and shipment time from BRP was too long, so I just got a regular 1156 build and used a Dremel to grind down one side, works great.
    Dec 2011
    Baltimore Ohio
    Default RT turn signal bulbs
    Thanks for the information on the bulbs. This is a new one on me and I'm ready for it when mine burn out on my 2010 RT.
    47234]The 1156 has a base designated as BA15S which includes pins that are 180 degrees apart. You need a bulb with a base designation of BAU15S which includes pins that are offset not opposite each other. Both bulbs have an S8 shape so they look similar but the pins are not.[/QUOTE]
    Jul 2011
    PA
    I got correct spare back-up and turn signal bulbs on e-bay. The turn-signal bulb (with offset pins) for $6.50 from AutoLampsPlus. The back-up bulb (180-degree pins) from bigrodj for $5.44.
    Note that the 1156 is rated at 26.9W, 2.1 amps. The bulbs I purchased are 21 watts, 1.7 amps. The owner's manual specifies 20W for both bulbs. Normally I'd say brighter is better. Just be aware that you're drawing over 25% more amps than specified. Probably no big deal at these small amperages.
    May 2012
    stockbridge georgia
    Default 17638na napa bulb
    Quote Originally Posted by gypsy_100 View Post
    napa has this bulb 17638na under $3.00
    Jun 2012
    Cumberland Cove - Monterey, TN
    If you are interested in replacing the incandescents with LEDs you might try these:
    http://www.ebay.com/itm/140855347693...84.m1497.l2649
    I have them in my RT and they work great.
    Carl
    Jul 2011
    PA
    Quote Originally Posted by james danny View Post
    Good find. The on-line NAPA specs don't show the watts or amps or if the bulb is tinted but the base shows the 150-degree offset pins and the bulb shape as S8. Hopefully your packaging shows the watts. Next time I need one, I'll give NAPA a try. Thanks.
    Quote Originally Posted by quickster47 View Post
    Carl
    Thanks Carl! Did you have to order anything else to make sure that the flashing rates stayed normal?
