Results 1 to 18 of 18
    May 2010
    jacksonville fl
    Angry Spyder RT Steering
    Help, i have a Spyder RT and the steering is really acting bad, the spyder can not make a complete turn and tends to pull to the opposite of the way i'm turning. My local shop says there no codes in the system and they can't figure out the problem.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    A non-functional DPS will often not leave fault codes. A nuimber of owners have learned their Spyders had no power steering, although no fault codes were ever thrown. It sounds like a bad DPS, low/bad battery (or bad connection), or a wiring problem, although it could be a sensor issue. What year RT? The 2010s were subject to a steering recall and DPS replacement. If yours is a 2010, make sure that was done. Beyond that, have your dealer contact BRP dealer tech support for assistance troubleshooting and correcting the problem.
    May 2010
    jacksonville fl
    Default Thank you so much
    Thank you so much, i will relay this to my tech and hopefully this will work, because that is one thing i did notice is that it was getting harder to start like the battery was dying. its a 2011 Spyder RT
    Oct 2011
    Woodbine, GA
    Is that the same problem you had during the 7 bridges ride?
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by spence View Post
    The DPS is the largest single use of electrical power on the Spyder other than the starter. The battery should be tested and load tested. Your battery connections should also be checked for cleanliness and tightness, and both the front and rear frame grounds checked for tightness. The battery should also be checked for the ability to take and hold a charge, and it should be load tested. A bad DPS, that pulls too much amperage, can appear like a battery problem, so problems with the electrical system should be eliminated first, then the DPS evaluated.
    May 2010
    jacksonville fl
    Yep, same crap
    Quote Originally Posted by captblack View Post
    Keep us posted and let us know what happens. I have a new 2011 RT in the stable with 5K miles--so far so good--
    Nov 2012
    Macon, GA
    Well, there are some things that are just just fine because you don't know any better. That's the way I've been with my steering until reading this post. Steering my new RT requires a lot of push and pull on the handlebars. As a matter of fact, my biceps are aching as I write this response after my wife and I went out on the RT this afternoon.
    Just how is the steering supposed to feel? Someone please try to describe the steering as the way it's supposed to be. ...Gnirtsnod
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by gnirtsnod View Post
    Best thing you can do is ride a dealer demo or a friend's Spyder and compare. Oh...check your front tire pressures. Too low (or even the BRP spec) can make the Spyder harder to steer. This isn't an effortless steering system, though, yours may be normal. Be aware that power input drops off as speed increases. At highway speeds there is no power assist. That's why it is called dynamic power steering...it changes under different conditions.
    washington state
    Good to know all this stuff
    May 2010
    jacksonville fl
    Default Spyder Steering
    Will do, let you all know on Tuesday
    Since the DPS is such a voltage vampire; do you think that a weak or dying battery might make itself known with steering issues before anything else?
    May 2010
    jacksonville fl
    Default Spyder RT Steering
    Well replacing the Battery definitely solved the problem with the Steering issue, Big Shout out to Nancystoy and all the peeps, who gave me advise on my problem
    Oct 2011
    Woodbine, GA
    Yep, I saw it at the dealer yesterday and Travis said the battery fixed the problem. I'm glad it was simple ... I'm hoping they get mine fixed this afternoon (gear position sensor).
    Invalid Emails
    Ormond Beach FL
    Post Define DPS Steering
    As a Can Am new rider, less then 3,000 miles of seat time, I think I would do it this way. Sitting still it takes a lot of arm pressure to turn the wheels from lock to lock. Under way to make a u turn it would not take a quarter of the effort expended while sitting still. At highway speeds it takes it takes so little effort that you have to retrain yourself to relax and not death grip the bars.
    I find myself tight gripping the bars from time to time and my first indicator at highway speeds is it wanting to weave around or darting around. I have to tell myself to be cool and it straightens right up and flies straight and true.
    you could equate the effort to your car as sitting still to trying to turn the steering wheel to a non non engine on event and the rest to driving in congested traffic up driving at seventy MPH or greater in a drive by wire ps equipped car of today in comparison to one with hydraulic operated system..
    I tried various tire pressure settings and find eighteen psig to be the best for my RTL and my driving style.
    Default It's a real education here..!!
    Quote Originally Posted by jerpinoy View Post
    always room to learn..
    Very Active Member Boriken's Avatar
    Aug 2010
    Villas, New Jersey
    As Scotty mentioned low or uneven tire pressure could be the culprit, ask me how I know.
    Bryant, Arkansas
    Quote Originally Posted by Boriken View Post
    How do you know???
    Or was that one of them Rhetorical questions???
