Results 1 to 4 of 4
    Very Active Member SpydermanCT's Avatar
    Nov 2010
    Connecticut
    Default Cluster Replacement
    I have a 2010 RT and had my dash cluster replaced with the 2011 cluster. I recently did some night driving and noticed that the dash did not have a night mode like my 2010 did. The 2010 changed colors, it was darker with some of the display changing yellow, and seemed to dim somewhat when in the night mode. Do you think it is now working as designed (with the 2011 dash) or might there be something wrong with the dash or a related sensor ?
    SpydermanCT
    2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
    Mar 2008
    Allegan, MI
    The 2011 cluster also has night mode. Yours may be faulty.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Registered Users TuckMiddle's Avatar
    Sep 2011
    Waleska, GA
    Default Screen change after dark
    The one in my 2011 RT goes from white to dark blue in the main "screen" part. The "change arrows" do go to yellow, I just went out to the garage to check, threw my jacket over the "dashboard" and the two changes above are all I noticed.
    I'm normally too busy looking for deer on these country roads to notice very much else.
    Tuck
    Could this be something that is handled by the "Preferences" screen?
