Need for Speed
Folks,
I have a 2011 RS Spyder and like speed. I have installed the power commander and hindle exhaust. Anything else that I can add to give me more performance ( i.e. speed).
Bob L
NOS? Turbo? Actually if you already improved the exhaust, the easiest way is to improve the breathing at the intake end.
Since the 990 is basically the Aprilia Tuono 1000RSV motor (not the V4), you might look into what upgrades carry over from the superbike.
JLohPhotos
Better make sure Nanny approves or you will have to deal with the old B&@%H.
I agree with the intake, I have the Kewlmetal K&N setup. If nothing else it really opens up the engine area. Also Ron's sparkplug wires, and plugs, can't go wrong their....
Hindle exhaust, Kewlmetal K&N intake + prefilter, Kuryakyn widow pegs, Kuryakyn grips, Madstad 20in. windshield, Juice Box, 02Modifier, Kewlmetal backrest and carrier, missing air dam, missing belt shield, 1" riser, Kewlmetal handlebar risers,Evoluzione sway bar, Street Magic/Day Runner Pucks, Glo Riders Amsoil, 10w40, Rons performance wires
if you need speed you need good suspension
Ditto on the K N air filter. The suspension on the newer RS may be adequate but I had to spend $$ on my 08's suspension to get the most out the spyder. Went with the Elka shocks, over sized tires and Evolution sway bar.
... and brakes!
... and upgrade the brakes while you're at it, to haul you down from that new speed. Start with some performance brake pads, stainless braided brake lines, and high temp brake fluid.
JLohPhotos
