one more modulation
After much internet searching and a few phone calls I have found out that signal dynamics sells a modulator that can be wired only into the low beam, and that kisan makes a model (P115W-H3-HD) that also can be wired into the RT, but no plug and play modules for the RT. Apparently the RT is acknowledged by just these two. Anyone use either of these products? Satisfied? If another used, please specify product as it seems to be difficult to locate these for our bikes! Thanks!
RE: One More Modulation
You might take a closer look at the laws that regulate the use of a headlight modulator. A good source is www.kisontech.com they have link to DOT web site for you to read. Unless there is way to wire the modulator to the shudders (used to reduce the output) when fully open as in high beam mode this modification would not be legal. Modulated low beam headlights are not legal.
headlamp modulation
Originally Posted by SpydieRydie
... Modulated low beam headlights are not legal.
+I'm not sure that's accurate SR.
http://www.webbikeworld.com/Motorcyc...lator-regs.htm
Ride on.
Roadkill
hearlight modulators
I might be wrong but I posted my reply based on the documents provided to me by PENNDOT in Harrisburg PA in 2006! It's all good!
Originally Posted by Rattigan_Roger
crazy uncle Marty who was never quite right after he hit his head on the bottom of the swimming pool.
frickin uncle Marty always leading people astray..............
