Results 1 to 7 of 7
    Registered Users StSpyder09's Avatar
    Aug 2008
    PENSACOLA, FLORIDA
    Question "Red Dragon" (2009 RS SE5) stuck in 2nd gear?
    Hi All, Coming home two nights ago and Spyder went to second gear and will not come out. Will run, but can only go so fast in 2nd. Need oil change, but need to get there. How can I get it to change gears, so that I can get it to the dealer for service? At full stop, must rev engine to start moving (in 2nd). Any suggestions, other than the obvious, unaffordable, trailer it?
    Thanks for any and all assistance.
    D.L. Street
    St'09
    Jul 2011
    Mitchell, Ontario, Canada
    Sounds like your gear shift linkage came apart.
    x 2. Happened to me about a month or so ago.
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    Low oil level seems to make SE's do some "funky" things.
    Registered Users hrbeta's Avatar
    Nov 2011
    Boca Raton, FL
    Default "Red Dragon" (2009 RS SE5) stuck in 2nd gear?
    Check your oil level ASAP
    Aug 2008
    PENSACOLA, FLORIDA
    Default I Owe, I Owe, its off to the shop I go
    Oil level is good, so I guess it's off to the shop. Is that linkage something I can fix (having an average IQ)? Or is it definitely a shop thing?
    Thanks All!
    St'09
    Aug 2008
    PENSACOLA, FLORIDA
    Default So that's a gear linkage!
    After resolving to take Red Dragon to the shop. I decided to check the oil, one last time. While running I noticed something hitting the bottom panel from the inside (that can't be right!). I removed the panels to see the above image on the left. I'm not mechanically inclined, but it just didn't look right. I accessed my shop manual and what do you know, that's the Gear Shift Linkage that billybovine was talking about. I read how the dot should line up with the slot. loosened the allen screw, pushed it on, replaced the screw, said a prayer, and turned the key. An "E" flashed, then she went into "N". Tested reverse, then went for a short ryde. All is well. Red Dragon flies again. Thanks again to my "Spyder Friends"! You all are amazing.
    St'09
