Results 1 to 8 of 8
Thread: Risers
    Registered Users gdmkgm's Avatar
    Oct 2008
    HENDERSON TEXAS
    Default Risers
    Is there a riser or pull back kit for the RT's
    need to bring bars back 3 inches or so.
    Very Active Member napper39's Avatar
    Jul 2010
    kansas ottawa
    none for the rt,so most others have had there seats made to sit futher away or closer,which ever you need.
    Invalid Emails
    May 2011
    Gulf Coast of Texas
    Was looking into making a riser plate for our RT. But the TBW is making the application almost not worth the hassle. TBW...Throttle by Wire. I'm still trying to figure out an easy but cost effevtive way to make it happen.. The seating position is the best and most simple fix.
    Registered Users Adirondack Mik's Avatar
    Aug 2012
    Plattsburgh, NY
    The handle bars for the 2013 are adjustable, sold as an accessory, and fit earlier RT's.
    Mike
    Oct 2011
    Jacksonville, Fl
    We have a 2013 on order and I ordered the adjustable handlebars to be dealer installed and BRP has already shipped them and they are at the dealer's. You might want to check with BRP to see if the 2013 bars will fit your machine.
    Jan 2009
    austria
    does someone know if the 2013 modells have all the same wholes to fix the handlebars - if so - I hope someone makes an (aftermarket) adapter which could be used also for different applications on all modells ..
    Aug 2012
    Plattsburgh, NY
    The catalog indicated the bars would retro fit to earlier models.
    Mike
    Jan 2009
    austria
    I always wanted something like this here - for my GS and my RT and maybe my ST now ..
    http://www.lsl-motorradtechnik.de/php/index.php?l=en
