Page 1 of 3 123 LastLast
Results 1 to 25 of 51
    Sep 2012
    Junction City, KS, USA
    Default Mounting your Spyder
    In the month that I've had my Spyder, I find myself walking around it to mount for the left! Now, I always knew you should mount a horse from the left side because that's how Matt Dillon and John Wayne did it. When I rode 2-wheelers, I mounted from the left because they lean that way on the side stand.
    When I realized I was doing it, I started mounting for wherever was nearest, but I'm wondering if y'all have encountered this, too.
    Hmmmmm...... Is it the other way around Down Under?
    PrairieSpyder (Patti)
    From the left side only...
    Aug 2012
    CO
    Mounting it from the left came from the cavalry, when you wore your sword on your left hip. (Assuming you were right handed).
    Personally, I prefer taking a run from the back and vaulting onto the seat, Hollywood style.
    JLohPhotos
    2008 GS , Millennium Yellow
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default giblets
    Quote Originally Posted by asp125 View Post
    That sounds really hard on the giblets mount from left side, from many years of two wheelers.
    it was fun while it lasted.
    Very Active Member Ivorspyder's Avatar
    Palm City Florida
    If you rode a 2wheeler from the left.If not I would still mount it from the left.It seems the RIGHT thing to do
    Ivor
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    I originally found byself mounting from left side only but now pretty much which ever side is closer. Also mounting from the rear will be real hard on the gibblets if you have a backrest.
    I wish that I could vault onto it from the rear...
    There would be so many style points added for that!
    Aug 2012
    Las Vegas, NV
    Default Run, Jump, land softly !!
    What do you think "Pardner"? You don't want your to go into limp mode because it sensed unusual weight on the right hand side of the vehicle compared to programmed inputs.
    Active Member chisel_maker's Avatar
    Mar 2012
    Evergreen, CO
    Did I do it wrong?
    Spyderless Member
    Dec 2008
    north/central n.j.
    I only mount from the left, It's a holdover from 40+ and still riding Motorcycles.
    But if you mount your Spyder from the right side, and your dealer picks that up on BUDS,
    Most likely your warranty will be null and void.,
    I heard that had happen to my friend's brother in law's sister's cousin.
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    Mounted from the left on two wheelers. I mount from the right on my spyder because my right leg is my dominate leg. (I played basketball, I'm left handed and always used my right leg for layups)
    Chris
    Jun 2012
    Hampton, Virginia
    Post
    Almost always mount up from the left side. Seems easier for me to swing my right leg over the than my left leg...I'm right handed and guess I'm right legged as well.
    2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
    Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
    Jun 2012
    Hampton, Virginia
    Post
    Almost always mount up from the left side. Seems easier for me to swing my right leg over the than my left leg...I'm right handed and guess I'm right legged as well. Rather it is probably out of habit from riding 2 wheelers for many years.
    Registered Users farmerjim's Avatar
    Sikeston, Mo.
    My two cent's worth says, whatever floats your boat. Which ever way you wanna swing. Do what makes you VERY HAPPY. I DO!!!!
    Enjoy the Passage of Time with
    Hanover, PA
    We mount from the left. We never rode and just do it because well....... that is the way you get on a motorcycle!!!!
    Registered Users flybuddy's Avatar
    May 2012
    Fort Myers
    OUCH!! hope you wear a cup
    2012 Spyder RT
    Invalid Emails
    Jun 2012
    Laguna Niguel, CA
    Quote Originally Posted by farmerjim View Post
    Which side do you mount your boat?
    Invalid Emails
    Jun 2012
    Laguna Niguel, CA
    Most of the time on my Spyder I am lowered onto it by a heavy duty crane and placed in position.
    Mar 2008
    Allegan, MI
    As was said, horses are mounted from the left because that originated when calvalry wore swords. A right-handed swordsman would hang his sword on the left. Motorcycles and bicycles ended up with the kickstand on the left, so most riders mount from the low side...which is easier. (US motorcycle officers are taught to mount and dismount from the right, in many locations, because it is safer to get on and off away from traffic.) Most riders learned the left side mounting habit early on, and continue to do what they did on their bicycles and motorcycles (or horses). I usually mount from the left, even on a Spyder or motorcycle with a centerstand, for the same reasons (habit), but my wife mounts from the right, because her bionic right knee doesn't bend as well, making mounting from the left more difficult. Do whatever pleases you. There are some good reasons to mount from the right, but it is seldom done. Maybe you can start a new trend.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    I think that "Alaska's" right; you don't want to throw the Spyder into Limp Mode because of unusual inputs!
    Very Active Member MMcc's Avatar
    Aug 2010
    Annandale, MN
    Default Minority report
    Started to mount from the right side when I bought my first Spyder. Reason, it was a SE5 and I typically start it warming up while I put on the rest of my gear before mounting. Why the right? Most times I do not shift into neutral before I shut it down and need to depress the brake peddle to start it. Therefore I am on the right side. Works for me.
    Quote Originally Posted by chisel_maker View Post
    Did I do it wrong?
    It looks good to me!
    Aug 2012
    CO
    Quote Originally Posted by OldDog View Post
    I don't know any taxidermists in my neck of the woods that do it. (mount a Spyder)
    Mounted err... spider
    JLohPhotos
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default RIGHT
    LEFT is RIGHT, n RIGHT is WRONG....
    i hear that goes for 'boy earrings' too....
