SE5 Not revving after changing gear
Hi Guys,
I have a Roadster SE5, 12000km on the clock. Since I got it, it has always revved when i change down gear (all the gears except changing from 2nd to 1st). Now it stood for a week, and it doesn't rev anymore. I was wondering why its stopped? I also miss the sound! Anyone have any ideas?
Thanks,
Andrew
You posted this some time ago and no one responded...
Not sure what you are talking about with regard to "revving"...
Anytime you downshift to a lower gear the engine will have to speed-up to a higher RPM to maintain the same speed. This would be common. Reducing the revving can be done (somewhat) by braking as you downshift -- but not required -- but recommended to help avoid adding extra strain to the transmission, clutch and etc.
So... again... not sure what you are talking about; nor would I know why all of a sudden it is not "revving" on downshift. Maybe more explanation is needed.
Sounds like your "blipper" is malfunctioning:
It's odd that it doesn't appear to be something that kills the bike when it stops working...
Originally Posted by terminal
Hi Guys,
Thanks,
Andrew
Mine will do this but only if I wait too long to down shift. Maybe it's your technique?
