Will gloves help?
Hello all,
I've noticed that after riding that the palm area of my right hand feels a little irritated/sore. Would a nice pair of riding gloves help this or is this caused by the Kung fu grip that I have on the throttle?
Ease up on the kung fu grip for sure.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Gloves do help
Originally Posted by Laila's Dad
Hello all,
Relax your grip and try not to tense up. You won't tire out so quick while you're riding.
My opinion on the gloves, if I'm going on a long trip, gloves do help out.
aka Buffalo Bill
The standard grips on the hurt my hands even when I tried to relax. I've tried Kuryakin grips and the BRP comfort grips. Although I currently have the Kuryakins, the comforts grips with grip buddies were the most comfortable although not as "cool" looking.
My 2011 RSS SM5 Mods all self installed: Spyder Detailing Graphics, Madstad, Kewlmetal risers, Rivco Driver Floorboards, Evoluzione Sway Bar, 25" Touring Windshield, 2010 RT Shocks, Hindle Exhaust, Isci Handbrake, Kurakyn Grips , Rivco Passenger Floorboards, Tricled fender tips and fender lights. Rivco license plate flag holder. BRP backrest. ESI tail light lens.
If easing up on the grip doesn't completely do it, go here:
http://originalbeemerbuddies.com
They are a site sponsor.
Gloves
Right on about the grip, too tight a grip can lead to oversteer . Try to relax a bit, obviously you need to maintain throttle position. I wear gloves whenever I am riding, little things fly off the road, and bugs hitting your hands really sting!
2009 GS SE5 Silver
They don't look as bad when the seam isn't showing.
Have you tried a Throttle Rocker, one of those small plastic tabs that you put on the throttle grip? You can just rest the heal of your hand on it to maintain throttle position rather than grasping the throttle grip. I've used one for years on all sorts of bikes. They are cheap and they work. Good luck.
SpyderLovers Sponsor
Looks like you're riding the stock handlebar setup on an RS. This puts a lot of pressure on the palms of your hands from leaning into the bars.
It may be too tight a grip but if so, you're wrists and fingers will also be stiff/sore after a longer ride.
There are some great gloves on the market with some having gel pads or additional padding on the palm that you might try.
For warm weather I really like weight lifting gloves with open fingers. They give you great padding in the palm area, feel great on your hand, come in a lot of different styles (even some taylored for women) and colors, they last a long time, are easy to find and they don't cost much.
The only down side I've found is that sometimes the really cheap ones will leave color on your hands. But it washes off fairly easily.
I always wear gloves when i ride, Just a habit from riding Two wheelers for the last 40 years, So when i have to move my bikes around and don't bather to put them on i feel the gripes digging into my palm's, Also like mentioned before, The Throttle rocker is worth every penny, They also make them for the left grip and that will take pressure off your left palm.
The only reason I thoght that it may not be my grip itself is that my left hand palm doesn't have the soreness. I looked at the crampbuster online but didn't get it because I figured that it may be a user error because of my tight grip.
New Grips
I actually changed my grips to the
Kuryakyn Black ISO Grips (6341)
With Throttle Boss (6318)
The throttle boss is similar to the crampbuster. With the Throttle boss you can relax your fingers by using your palm. My opinion is that the Kuryakyn grips are more comfortable that the factory grips.
Gloves help
I wear gloves when ever I'm out just habit and as someone noted bugs etc can be distracting. When trying gloves on check carefully for inside seams that can be annoying after a while. My pair of half fingers has a seem in the right glove that hits in the web of my thumb and almost raises a blister on a long ride. Lots of leather dressing helped but so does moleskin or a bandaid .
Ride safe,
Curt
I believe it's the right palm b/c of the pressure you place on it when twisting the throttle; as your wrist extends, your fingers tighten/flex around the grip.
Motorbike Professor
Standard motorcycle gear (ATGATT) includes gloves. I never ride without them. One of the easiest and cheapest solutions is to buy a pair of deerskin work gloves at the home improvement store. They offer good protection, are not damaged by water, and can be bought new for every riding season if you wish. I have lots of riding gloves, but wear the deerskin work gloves the most often.
...and lighten up on that grip!
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
GOS member (Girls On Spyders)
COMFORT GLOVES
You could go to a good Bicycle shop and try some " padded " Bike gloves........just a thought......Mike
Does anyone know how the Kuryakyn ISO Grips work with the RT's heat feature?
There's a lot of "mechanical cures" in here...
Why not just try relaxing your grip first, and then see what happens.
Tennis Racket Handle Wrap
Pick up a set of tennis handle wraps at any sporting goods store and wrap it around the grips. Has a bit of softness to them without making the grip bulky. Been using mine for about a year and they hold up well. Some have small holes which make for positive grip.
Manual labor will toughen up your palms
standard grips
hi i also think you need to loosen your grip but some gloves and grips (the standard grips on the spyder are amongst the worst ive ever ridden with ) would help i put on grip puppies to make the grips fatter and softer = more comfortable for me
cheers mick
When I first started riding I did the death grip too. My hands really hurt after a ride. It didn't take me long to learn to lighten up on my grip. But, I do find that wearing glove still helps my hands feel better so I wear them often.
If you ride any kind of motorcycle, including the Spyder, you really should wear proper riding gloves for safety (as well as all the other gear). Quality riding gloves are designed to be comfortable and will resist bursting seams plus they will stay on your hands if you contact the road. No other glove type will combine these safety factors for riders but remember, quality is all important! Just my opinion but you should avoid using gloves that are not designed specifically for motorcycle riding.
