Page 1 of 2 12 LastLast
Results 1 to 25 of 30
    Kansas
    Default Windshield Motor Suport Arm
    The arm that attaches to the windshield motor to raise and lower the windshield broke this morning. The dealer says I have to buy the whole motor assenbly at $480. All I need is the arm that connects the motor to the windshield. Any sugestions?
    If you hit Can Am's website; they've got a parts list area that you could dig around in to see if that part is listed separately or not...
    http://epc.brp.com/SiteMods/BRP_Publ...rands=roadster
    Jul 2011
    Hanford, Ca.
    Or you can go here http://www.martinmotorsports.ca/fich...ion_detail.asp all parts are listed and priced.
    Kansas
    The arm is listed with the motor. I was wondering who makes the arm for Can Am? If I can find them I may be able to purchase the arm.
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Ref your Windshield Motor support Arm
    There has been a problem with some of these in the Past - See
    http://www.spyderlovers.com/forums/s...n-your-machine
    I had my broken support arm replaced under warranty - Even if yours is not under warranty BRP must be aware of some poorly made ones which had already been fitted and hopefully will do the right thing and replace yours.
    The link will provide some evidence of a known problem - Let your dealer know they may take up the claim on your behalf
    Good Luck
    Eddie Sheppard
    Reading UK
    Active Member RAYYOU's Avatar
    Feb 2011
    Beaumont,Texas
    Mine has been replaced twice under warranty.
    Jun 2010
    Las Vegas
    Mine broke and I had Cowtown fix it last week. New motor was installed all under Best warranty.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Lightbulb I would think this should be covered under Warranty. . . . its a known problem
    As suggested, I posted a WARNING Thread about this when ours failed & it was covered under Warranty. And even back then, they had to order the entire assembly with the motor
    Kansas
    Default Windshield support arm
    Quote Originally Posted by CyncySpyder View Post
    Just got off the phone with the dealer and BRP is going to cover the part under warranty. They are not going to cover labor. The dealer is going to let me put it on. Any tips on how hard they are to install?
    Mar 2012
    London, Ontario, Canada
    Quote Originally Posted by jmstiffany View Post
    Awesome news..........we should recognize BRP when they step up and do the right thing.
    Very Active Member SpydermanCT's Avatar
    Nov 2010
    Connecticut
    I had done a pre-flight inspection this past weekend and noticed mine was cracked also. I have a service appointment next week to have mine replaced. I'm still within 2years of ownership so it will be replaced free under warranty. Definately something all RT owners should check on a regular basis.
    SpydermanCT
    2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    Anytime I have had to have anything done/replaced under warranty, BRP always said that it had to be done/replaced by the dealer. Me thinks your dealer is double dipping in the money jar! What you do (suggesting) is pick up the part, take it home, then call BRP customer service and inform them what has transpired.
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Mar 2012
    Quote Originally Posted by Dudley View Post
    Normally I believe you are correct warranty repairs are completed by the dealer. But I believe this is not really a warranty repair as the warranty has expired? Quite common to "give" the part away when a recognized defect is noted. There is a good chance the vendor of the part has extended a longer warranty period to BRP. However this is good customer service even though in theory they owe the consumer nothing.
    Now if the dealer wanted to offer good customer service perhaps they would install at N/C? However where you bought the bike, where it has been serviced previously and the opportunity that you will return if they cough it up is a question they will weigh in their decision making process.
    May 2012
    Jacksonville, IL
    It isn't hard to replace, there is just a lot that has to come off to get to it.
    Kansas
    Quote Originally Posted by vrodrjs View Post
    Any tips you can give me? Starting to remove this morning.
    Thinks out loud
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    7. WHAT BRP WILL DO
    BRP’s obligations under this warranty are limited to, at its sole discretion, repairingparts found defective under normal use, maintenance and service, or replacing such parts with new genuine Spyder parts without charge for parts and labor, at any authorized Spyder Dealer during the warranty coverage period.
    http://www.spyderlovers.com/forums/showthread.php?43651-Opinion
    Kansas
    Default Windshield Support Arm
    The new parts from the dealer won't be here before we leave for Colorado. I was able to remove the broken arm and take it to a welding shop in town. They were able to weld the arm and I put it back together and it seems very sturdy. I however now can't raise the windshield, it wil go down but not up. I will have to look into it when the new parts arrive. At least I am back on the road. :-)
    May 2012
    Jacksonville, IL
    I bought the shop manual when I bought my RT, if you have that there is a section in there that steps you through everything. Nothing tricky about it.
    illinois
    Default windshield motor arm
    My motor arm broke on my windshield , 2012 rts , guess i'm going to have the dealer repair it since nothing is easy to repair on a spyder & it's under warrenty , even to change a battery or do a oil change is difficult on a spyder. Sounds like this is a common problem with the windshield arms breaking..
    Danbury Connecticut
    Quote Originally Posted by SpydermanCT View Post
    I had mine replaced under warranty with about 12K on the bike.
    The new one looks exactly like the old one. There are no obvious changes to the design.
    I have close to 25K on the Spyder now.
    If mine breaks again, I'm going to take the broken aluminum part down to the shop and have them make me up a new arm out of Stainless Steel.
    There is definitely something wrong with the design of this arm, or there was a run of bad castings.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Jun 2011
    Lynden, WA
    Hope I can remember all the parts to take off but you need to remove:
    • Mirrors
    • Clear wind deflectors (lower)
    • Black access panels under trunk lid
    • Upper side panels (both sides)
    • Front Fascia (around head lights)
    • Clear wind deflectors (upper)
    • Windshield
    • Dash Cover
    That will get you to the arm, it removes with a circlip if I recall correctly
    Apr 2012
    NEW YORK CITY, NEW YORK
    Default front piece just broke
    I have a 2011 RTSE and was pulling out of a parking space and low and behold all of a sudden the windshield droped down towards the top of the dash and when I dismounted I discovered that this "dog bone" lift piece was broken. I was not doing and raising or lowering at the time of the windshield just moving about 5mph. This is clearly not only a poor design but probably a defective piece of cast metal. BRP should recall all units and replace them this could prove dangerous if driving on a highway if nothing else the surprise of it falling towards the driver. I am glad it was not in the up position as I sit forward on the seat and it probably would have clipped my face. If BRP does not replace this part gratis as I have a 5 year warantee, I will take them to court and also report this as a needed recall to the dept. of transportation as well as the dept of commerce. THIS IS A DANGEROUS DESIGN AND A FAULTY CASTING!!!!!
    Jul 2014
    United States
    Wasn't someone marketing an aftermarket arm some time ago? What happened with that?
    Feb 2009
    Canby, OR
    Yes - and it came from "noboot" in Australia. It was $120, but worth every dime. There's also installation instructions in the DYI section, and reading that is CRITICAL. If you do it wrong, your windshield will no longer work.
    Mine was NOT cracked, but I replaced it anyway.
    Northern Kalifornia
    Default If ir breaks again here's the fix
