Thanks Thanks:  0
Likes Likes:  1
Results 1 to 10 of 10
Thread: Heat deflector
    Junior Member
    Sep 2012
    Arkansas
    Default Heat deflector
    Hello, I have two issues...1) my spyder's temp gauge runs about 3 bars from maximum. It runs fine. I just rode it over 100miles without it overheating. The fluid levels are full. Is this normal? 2) Is there a heat deflector? The heat coming off the motor is too much for the boss lady. Thank you!
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    First of all; Welcome to the Parteee!
    I think that we might need a little bit of information about just which model Spyder you're riding in order to give you any decent advice...
    If my Ass is in the saddle: my head is in the clouds!
    2010 RT A&C...............2014 RT-L...................2018 10th Year RT-L
    ............Gone; but not forgotten!!................... The Latest, and Best!
    Senior Member quickster47's Avatar
    Jun 2012
    Cumberland Cove - Monterey, TN
    Yep, we need more input from you so we don't give you any wrong advice.
    Carl
    2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
    Senior Member dryheat's Avatar
    Feb 2008
    Oro Valley, AZ
    You are in Arkansas in the summer time, what did you expect?
    In hot climate, engine temps regularly fluctuate between 4-5 bars, depending on model and when the fan kicks on. You may hit 6 bars now and then... especially sitting in traffic. Not to worry. There are many threads on the topic, try some searches and you will learn more than you wanted to know.
    pe 792; Hindle, performance filter, O2 mod, custom seat, NMN risers, F1 Slider, cowl vents, cold air induction, Triple play, Tipz kit, highway pegs, Kury ISO pegs, grips and throttle lock, 3 gal aux Tour Tank on custom rack.
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Default Heat
    Spyder pops has some things that will help with the heat for Rt or Rs.
    4" Stubby antenna,Rivco Flag Holder,Third brake light & Run brake and turn,mirror blinkers, cup holder, BRP 25 inch vented windshield ,Spyderpops Bumpskid with inlaid led, w/remote,Spyclops light,Eagle etching on windshield w/light,ground effects,trunk light,volt,meter&dual usb,Ultma seat w/gas door,sway bar&links,1330&Spyder decals,JT dash mount.
    Led head and fog lights
    Active Member ornerydog7's Avatar
    Sep 2011
    Allen, TX
    2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
    Junior Member
    Sep 2012
    Arkansas
    Default Thanks
    Thank you all for the input. It is hot in Arkansas (102 last weekend), and it is expected, but just wanting to make sure. I have a 2009 Spyder GS. It does have the Hindle exhaust, but that is all for "performance" mods.
    May 2012
    Pearland (near Houston), TX, USA
    Just in case you weren't aware, you have the authority (and heck of a nice guy) on Spyder heat management in the same state as you. His name is Harvey Clark but he goes by "Spyderpops". A quick google search will turn him up. He is a site sponsor and has a shop near Hot Springs. Look him up, do a little research, and ask the questions.
    David
    Senior Member Recluze's Avatar
    Jan 2009
    Manteca, Ca
    Let me see if I can sum it up for you:
    If you are not in limp mode-you are not overheated.
    If the fan relay and the fan are working you won't go into limp mode.
    If the fan relay and the fan are not working you will go into limp mode, especially in slow driving.
    The SpyderPops stuff is great but won't fix a cooling system defect.
    http://bobspyder.wordpress.com/
    #610 2007-2009
    #104 2012....
    Bryant, Arkansas
    Arback, where are you in Arkansas, we are in Bryant and looking for other spyder folks to ride with
    Joe
    Sent from my iPad 3 using Tapatalk HD
    2018 F3 Limited, BRP Driver Backrest, Spyderpops Lighted Bump Skid, Mirror Turn Signals, Laser Alignment, Engine LEDs, Fog Lights With Halo's, Cushion Handgrips, BRT LEDs, and Under Lighting, Lamonster IPS, (with Clock), F4 25" Vented Windshield, Airhawk "R" Cushions. Position 4 Brake setting, Short reach Handlebars, Dash Mounted Voltmeter and 12 Volt Plug. Set of 3rd pegs.
