Page 1 of 2 12 LastLast
Results 1 to 25 of 33
    Nov 2011
    Las Vegas, NV
    Default Record Gas Milage?
    I think my current tank is headed towards some sort of personal record on my gas milage. On our ride today, we started with a full tank. I looked down and saw I had 60 miles on the tank and still had 7/9 gas bars remaning. It didn't drop down to 6/9 until well after 70 miles. When my light goes on at 1 bar, i can fit 5 gallons in. 9-1=8 bars = 5 gallons. 8/5=.625 gallons/bar*2 missing bars = 1.25 gallons used for 70 miles (56 mpg). Im sure each bar isn't .625 gallons in reality. I want to say the first couple are closer to .8 gallons. regardless how you look at it, this tank is doing really well. Im getting the impression the 76 gas station by my house doesnt have very good gas, since todays fill up was at a Rebel near my dealer.
    magical member
    May 2012
    Bellingham MA
    Estimated 56 mpg, that's better than my Prius.
    Maybe you put a little more in than usual at the gas station for the ride. Topping off will cause the first bar to take longer to disappear.
    I was just about to comment on my choice of gas and deleted it, that's a whole can of worms I don't want to open.
    Harry
    Very Active Member btcherm's Avatar
    Howard City, Michigan
    Default gas
    wow that good I'm only getting about 31mi.
    Feb 2012
    Portsmouth, Va.
    I think someone put some gas in your tank when you were not looking
    You better drain some out of that tank before it overflows all over the blacktop...
    Jun 2010
    Las Vegas
    A couple of questions. Where did you ride to? How many showed up?
    As for gas mileage i got 34 mpg on a tank on this trip pulling a fully loaded trailer. I have never before. How did I do it? My new Two Brothers exhaust and speeds averaging around 62 mph.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Arr,
    Be careful of that last bar.....it can be deceiving.
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default MPG
    my SPYD3R is an '09 RS w/23,000 miles... i constantly monitor my 'mpg'... i check it after every ride and to date, my results have been: 1. with OEM tires & OEM muffler, 33 mpg average. 2. with KUMHO @ all 3 corners & performance muffler, 35 mpg... i've found that the 1st bar takes about 60 miles before it goes... but don't let that be a true indicator of what's happening in your tank... just enjoy the ride...
    see you all @ LAMONSTERS this coming weekend...
    Nov 2011
    Las Vegas, NV
    Quote Originally Posted by harrypottar View Post
    Harry
    Nope. I don't top off. I use the exact same gassing procedures every time. Put the tip of the nozzle right at the opening, fill until I begin seeing splashback then stop.
    Nov 2011
    Las Vegas, NV
    Quote Originally Posted by SpyderAnn01 View Post
    Ended up going to willow beach since those that came wanted a short ride to stay out of the heat. Myself, Fred, and the turkeys came on the ride, and the Simpsons showed up at the meeting.
    Sep 2011
    Waleska, GA
    Default Fuel gage "squares"
    Quote Originally Posted by Arr MiHardies View Post
    My RT digital fuel gauge's first square goes out at about 50 miles, the rest of em vary from 10 to 20. When there's only one square left, it'll take about 5+/- a little at 160 to 180 miles. No sense watchin it, just acts like most cars and bikes, almost useless. My Prius has been at 2 boxes left right now, for about 75 miles and 360 total on this fillup. Then they both will disappear around 400 and it'll take 9 or so out of the 11 something capacity of the tank. All the hills here keep it below 46 mpg normally. And, I can fill it up and it won't boil and belch and stink up the garage like my 3 wheel's gas tank. Life's a bi... sometimes, ain't it?
    Tuck
    Let us know how many gallons/miles are involved at the next fill up. Looking at the bars--it always seems to take forever for the first two to get used up--from that point on--I seem to lose a bar every 25 miles or so. My overall average is still about 34 mpg on pretty much every tank.
    Franklin, NC
    Default Re: Record Gas Milage?
    Quote Originally Posted by SPYD3R View Post
    Boy you sure do get around!
    Sent from my AT100 using Tapatalk 2
    Hanover, PA
    Default Started tracking
    We have a 2011 RT with stock muffler and no performance enhancements. I just recently started tracking MPG and yesterday I averaged 32. Avergave speed around 57.
    Default MILEAGE RECORD
    56 MPG .... I got $10,000 says it's not happening with a normal customer owned Spyder......Not even downhill with a steady tailwind...and especially not with an RT.....You have set a record but not for gas mileage.....sorry .....Mike....
    Invalid Emails
    Dec 2010
    Augusta Georgia
    Maybe he has the first Spyder Hybrid. Part reality part whatever.
    May 2010
    Knob Noster, MO.
    about the gas, as I do seem to get better MPG on one brand of gas compared to another brand. Won't give names as I don't want to open that can of worms.
    When we went up to SITR, and we stopped for gas about every 120 miles I would always be on bar three, but one time I was on bar two at 100 miles. We rode the same speeds, and conditions. The difference I think was the gas (don't remember gas brands).
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Invalid Emails
    Dec 2008
    Mexico City, Mexico
    I've found that I get better gas mileage from my Cadillac Escalade using Mexico's no alcahol added gasoline rather than using the alcahol added gas I bought the last time (1 month ago) I was in the States. Though my gas milage in both areas is lousey, pulling my trailer loaded with my Spyder, it's about 2 mpg better using the Mexican regular octane gasoline, all other condition the same. That's about 20% more out of a gallon of gas. Do your math fellows. I drive a real gas guzzler.
    Invalid Emails
    May 2012
    Wilkes-Barre PA
    Default Gas Mileage
    A friend of mine bought a VW beetle and always braged about the gas mileage. He always parked it in his driveway at night. We would sneak up to his houe and add extra gas. Boy was he bragging now about the gas mileage which was close to 70 miles per gallon. After a while we listened to his stories and then we started siphoning about a gallon out. Now his gas mileage dropped down to 20 miles per gallon. He took it back to the dealer and they could not find anything wrong.Was he ever mad when we told him the truth. Then he started to laugh and said that was a good one but I owe you guys one.
    Nov 2011
    Las Vegas, NV
    I was down about 5 bars when I gassed up today at nearly 100 miles. Fit 3.2 gallons in. For almost right at 30 mpg. Not so groundbreaking I guess. still better than the 22 mpg I got on the previous tank.
    But it sure was fun while it lasted!
    Default 22 mpg
    What happened to 56 MPG ..I can tell you, you are using the most inaccurate measuring device ever invented to try and give you an exact measurment namely your FUEL guage....that thing is a joke.....You fill tank to brim zero the odo,..drive till you fill tank to the brim zero odo...do this at least 10 times add all the miles and all the gals. and divide ....then you will have a reasonable estimate of your average MPG. but it's still only an estimate. My average is 38-39 mpg 08 GS based on about 3000 miles ...and I have the gas receipts to prove it....
    Nov 2011
    Las Vegas, NV
    I use Fuelly. It gives me an average of All my tanks of gas. I was just seeing what looked to be a really good tank of gas. And it ended up only being slightly better than average.
    Sent from my HTC VLE_U using Tapatalk 2
    Oct 2007
    I for the most part use 87 octane with no ethanol. I put the
    Nozzle in half way when filling up. I've been getting between 170mpg to 190mpg per tank. I guess that is average from what I've seen on this forum
    Default NEW MILEAGE WINNER
    Quote Originally Posted by Slickrick View Post
    I declare Slickrick the absolute uncontested mileage winner..No-one else need apply... ...Mike
