Results 1 to 7 of 7
    Active Member Mowerman's Avatar
    Apr 2010
    Altoona, Iowa
    Default resetting sensors
    How long shouldit take for the dealership to hook up to Buds .Then Recalibrate the Steering angle sensor and the steering torque sensor?
    Proud Owner of a 2017 f3t
    arntufun
    Guest
    About 5 minutes !!!!!! I just had mine done a couple of months ago (steering angle sensor).
    Re-setting the sensors shouldn't be much of a process; the Tech re-set my Throttle Position Sensor the last time mine was in the shop. not that it fixed anything...
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Quote Originally Posted by Mowerman View Post
    Well you need to fill out the paperwork. Then they bring the Spyder into the service bay.... then the tech positions it in the proper place. A quick break away for coffee. Then open the frunk.... remove the buds cover and attach the leads. Then turn on the monitor and select the correct menu. Then align the bars perfectly and finally re-calibrate.
    Should use up about and hour, I'd say.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Quote Originally Posted by Double Trouble View Post
    You forgot the phone call to BRP to ask them how to do it...
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    Default HOOKING UP BUDS
    3 WEEKS AT MOST.......Mike
    Quote Originally Posted by spyder3 View Post
    And then they disappear on break after they're done, but forget to sign off the job... The bike is sitting in the back of the building waiting for them to return...
