Results 1 to 19 of 19
    Apr 2012
    Vermont, Shelburne
    Default Exhaust gaskets?
    All you high milers, when your exhaust gaskets went bad were there any codes thrown by the computer. I know on most cars with an exhaust leak before O2 sensor, codes will show up due to false mixture. Just curious to see if this happened and if a way to tell if its leaking before a full blowout. Steve
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default no codes
    mine just started running bad. occasional backfire, cracking and popping, in the 4k rpm range. turns out just the right side clamp was loose. i put in honda gaskets anyway, to be done with it. happy ending.
    it was fun while it lasted.
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Quote Originally Posted by coz View Post
    Is there a specific Honda gasket? Perhaps a part number?
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Oct 2009
    ponte vedra beach fl
    Quote Originally Posted by 800steve View Post
    i have replaced mine 3 times the last time with the honda gaskets
    74k no codes thrown. it just started backfiring.
    Jackson, NJ
    Quote Originally Posted by DR Buck View Post
    Honda Gasket [goldwing]# 18392-MAM-000
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by juliantrost View Post
    If I'm not mistaken the Honda gasket's won't fit an RT!
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by boborgera View Post
    That is correct.
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    Had the right side gasket burn out at around 7-8k. No codes thrown, just poor performance and a very hot right leg. At 31k now with the Honda gaskets and going good.
    Hope the RT crowd finds a good non-OEM replacement...
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
    Invalid Emails
    Adelaide South Australia
    does anyone know the honda part number for the slip joint gasket for the RT
    Spyderless Member
    Dec 2008
    north/central n.j.
    BUMP,!!
    Invalid Emails
    I know the RS gasket will not fit the RT but is there another gasket number to replace it. After market one?
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by babeshorty View Post
    I could be wrong, But i don't think there is , At least if there is' It hasn't been posted.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    There is none that I know of. The RT gaskets are far more robust, however, so the factory gaskets have not been a problem. If it ain't broke, don't fix it.
    Oct 2009
    Martin, SC
    Quote Originally Posted by NancysToy View Post
    It is my understanding that BRP actually looked into the exhaust gasket issue and made improvements based on all of us who were changing to the Honda gaskets on our GS Spyders.
    Invalid Emails
    Dec 2012
    Tollison, AZ
    Default RSS Exhaust Gasket
    I an going to reinstall my OEM RSS muffler, but I need the Honda part number for the gasket from the y pipe to the muffler. thanks for the help
    Default THE LARGEST GASKET
    Quote Originally Posted by master1309 View Post
    I believe you are talking about the actual MUFFLER GASKET ? ??..If so the Honda gasket is only for the smaller exhaust pipes......Mike
    Motorbike Professor
    Mar 2008
    Allegan, MI
    You need to use the BRP gasket. There is no Honda equivalent for the muffler gasket.
    Default Don't know..!!
    about any codes...but you will feel the heat....!! and some barking..!!
    No need for an injection of Honda DNA in this case.
