Results 1 to 7 of 7
Thread: "Brake Failure"
    Apr 2009
    Round Lake, Illinois
    Default "Brake Failure"
    I was riding to work this morning on my usual route, when I came to a downhill section of road where the speed limit drops from 45 to 35. I typically just down shift in this section and let the Spyder engine brack to slow down, which is what I did this morning. I happened to look down to check my speed ( as this area is a speed trap) and noticed the brake light indicator was illuminated on the gage cluster, then suddenly, the display flashed an orange warning "Brake Failure". It only lasted a couple of seconds and then disappeared from the display. It didn't do it again, but I was only a mile or so from work so I've not ridden it any great distance since this incident. Just curious to know if anyone else has had this type of experience? I ride a 2010 RTS.
    Jun 2011
    Killeen TX
    I had this happen to me going downhill ... check the fluid in the resevoir ... My fluid was not low enough to see but I added a little and it cured the fault ... ... the spyder is very sensitive to these things ... btw ... the only time I got this brake failure was going downhill while engine braking!!! ... hope this helps!
    Motorbike Professor
    Mar 2008
    Allegan, MI
    As was said, check the fluid level in the reservoir. Even a tiny bit low causes a warning, especially on change of grade, acceleration, or brake application.
    May 2011
    Calgary, Alberta, Canada
    Agreed x 3
    Agree x 4
    Oh... Let's make it an even number...
    Agreed X 5!
    Apr 2009
    Quote Originally Posted by stutzmason View Post
    Thanks, will do.
