Need Advice: Installed a muffler and got Limp Mode
Hi everybody,
Limp Mode finally got me. That'll teach me to talk smack about the RT's.
But seriously--I ride an '09 RS and have never had a single error code. Within 6 days of installing a 2 Brothers Slip-On exhaust (Vale M-2), Limp mode hit me and now I can't go over 3,500 RPMs. I remembered from the RT folks to turn it off, walk 30 feet away, and try again--but that hasn't worked. I let it sit all weekend with the key out and far away, but it still has the same issue. Does anyone have any advice? I'm getting the DPS, ABS failure, and VSS failure codes with the check engine light and the constant "Limp Home Mode" scrolling across. Major bummer...especially considering my Spyder is my primary form of transportation.
Thanks in advance for any useful advice.
Best,
--Andy
2009 RS SM5. Passenger Backrest,
Sport Rack, GloRyders, TricLED Dayrunners,
LED Halo Kit, and LED fender tips.
SpyderLovers Founder
Hey Andy,
I'm sorry about problem. I certainly don't think it has anything to do with the exhaust. That's the same one I have.
I think Lamont has a point about the battery. Good luck and let us know turns out.
Bill
Pride Runs Deep Semper Tacitus
An armed man is a Citizen; an unarmed man is a subject....
2017 F3 T SE6
2015 Vulcan Vaquero ABS
ALR Chapter 401 (Hilliard FL)
GA & FL Patriot Guard
Originally Posted by Lamonster
How's the battery?
The battery seems fine. I turn the key and everything comes on no problem. And it starts up just fine. But all the faults are clearly there and I can't exceed 3,500 RPMs. Frustrating.
She just need a little break from all your fast riding.
2014 RT Limited Cognac ----- Wraps, skid plate, lights, Elkas
2002 harley ultra classic
2008 hayabusa
Just for grins you might try reseating the major relays under the trunk lid.
Very Happy Spyder Guy
The 2015 F3 has over 46,000 miles
Have Spyder...Will Travel
battery cable loose or bad relars or fuse bad or blowen.thats all i got.
MOgang Member
Maybe the O2 sensor got bumped during the installation?
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
It's just a slip-on. Pulled the old one off & put the new one on. Is there an O2 sensor underneath? Seems weird that it would run like a champ for 6 days and then all of a sudden I hit Limp Mode. As a matter of fact--it went Limp Mode while I was riding home. I went to throttle up and *gurgle gurgle gurgel*...you know the deal. I was like "what the heck?" because I had never experienced Limp Mode.
I'll try everything you guys are suggesting to be sure. And thanks for the condolences Bill.
Well I checked all the fuses in the frunk and under the seat. No issues. I checked the battery. Everything is tight. I went ahead and stripped it down and put in a new K&N high performance air filter. We'll see if that does anything. Next step is to put her back together and put on the old muffler and see if that helps. I'll keep ya posted.
Disconnect battery for a while and reconnect. It will at least get rid of limp mode and other fault lights.
6 states down 42 states to go
I will try that today. Thanks!!
Curious: how long is "a while"? I disconnected for about 5 minutes, and the reconnected and the faults are still there.
There was another thread on here and it recommended disconnecting the battery for 30 minutes.
2012 RS SE - White. Sport rack with Backrest, ISCI Armrests, Two Brothers Exhaust
I'll throw in my 2 cents. The battery is probably low. It doesn't take much power to bring up the dash gauges but if you get the holy trinity of faults at the same time it's pretty commonly caused by low voltage. Check the battery voltage. If you can't, plug it into a charger and charge it up good, then reset it by disconnecting for 20-30 minutes (5 is probably enough but who knows?) and see if the faults go away and it starts.
tHe SmOkEr YoU dRiNk ThE pLaYeR yOu GeT!
but he can start it - just not get over 3500 rpm. Would seem the battery is ok - but the faults wont clear.
MODS 2013 - Ultimate, Remote / LED Halos, Pete's Dash kits , Elka's!
2011 RT A&C-SM5 - Orbital Blue (mine)
Xenon Lights, Polk speakers (4), 5-LED lamps, fog lights, Sypderpops grills, OGB grips, TIPS and CHANNELZ lights. Seal FLRBDS, Two Brothers Muffler, ZUMO 665 w XM, Gloryders, HMT Brake.
2012 RT-LTD SE5 -Lava (hers)
MODS: Spyderpops chrome grills, TIPS and CHANNELZ lights, HMT Brake, Seal FLRBDS, Gloryders, OGB Grips
limp mode
i have herd mention several things to try when i was experiencing the same issues but no muffler exchange mine was caused by brake lights issue i changed to led lights in the brake light sockets and it was throwing the bike to fits of limp mode ABS VSS and Brake failure all due to the lower amp usage of the bulbs
Well, I left the batter disconnected at lunch and l'll try again when I get home tonight. That will give it several hours disconnected. I'm beginning to wonder if maybe I have too many LEDs connected. I'll try disconnecting some of them and see if that works. Thanks everyone for all your help. I remember I got an ABS failure once and all it took was a little DOT-3 fluid as recommended by a Spyderlover. I'm still hoping this is something simple and don't have to go pay through the nose at the dealer. They want $90 just to hook it up to the computer. I'm going through Spyder withdrawls!!
Registered User
faults
maybe a long shot, but check the oil level. Had it happen to me - check engine light, O2 sensor code and other stuff popping up on the display.
Doesn't hurt to check
Motorbike Professor
Instead of all this wild guessing, display the active fault codes next time. That may tell us where to look.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
dot four
my owners manual says dot four.
it was fun while it lasted.
Maybe it was DOT-4. I got whatever the manual said.
I hooked the battery back up last night but no luck. Can anyone tell me how to find the fault codes on an RS?
Motorbike Professor
1. Turn ignition key on
2. Press mode repeatedly to show engine hours on display
3. Start engine and run until warning is displayed
4. Press and hold mode button while pushing the "flash high beams" rapidly five times. If not completed within 2 seconds, you will have to repeat the complete procedure.
Fault code(s) will be displayed or "No Active Fault Codes" will be shown.
-Scotty
OC 1230
1P2545
What do those mean?
