Results 1 to 3 of 3
    Very Active Member mike3069's Avatar
    May 2008
    Saratoga Springs, NY
    Default Rear shock replacement question
    I need a new rear shock. My question is what is the difference between the rear shock on the RS and the RS-S? The RS shocks are listed as not available until Aug. 15, but the RS-S shock is available (I have an '08 GS/RS). Anyone know?
    The glass is half full.
    Mike Murphy
    Happy Spyder Owner
    Jul 2011
    Kresgeville PA
    I have a 08 gs and recently purchased a stage one Elka with preload adjuster. I am not happy with this purchase as the set up is very stiff and has not improved the ride for my passenger. I am currnently in contact with John from Elka to resolve this issue. As I was told BRP changed the shock mounting points on the 2010 and newer spyders to accomidate a shock with longer travel. This mayber why you are seeing different part numbers.
    Does any one out there have a good set up for an Elka rear on an 08 GS?
    May 2008
    Quote Originally Posted by Jesse View Post
    Thanks Jesse! That's what I wanted to know.
    Mike Murphy
    Happy Spyder Owner
