Thanks Thanks:  4
Likes Likes:  4
Results 1 to 23 of 23
    Active Member BlueKnight's Avatar
    Feb 2011
    Hamburg, New York
    Default Cheap tow behind trailer !
    Harborfreight tag-a-long trailer...................on sale 399.00.
    http://www.harborfreight.com/automot...ler-66771.html
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    Oh yeah, I got mine with a 20% coupon for $320, if you get one, check the wiring, there were lots of bare ends on mine.
    john
    HAPPY SPYDER OWNER
    2012 Black Currant RT-S, Biker's Cross, BRP 23 inch vented windshield, BRP adjustable air deflectors, Spyderflap, Seal floorboards, Tricled foam grips
    Very Active Member spydaman60's Avatar
    May 2012
    sussex, nj and tug hill, ny (west turin)
    anybody know anyone with an rs that has towed one like this before? looks like the ticket for camping.
    Senior Member JJW SpyderRider's Avatar
    Jun 2010
    Rockton, IL
    I saw these on sale also at my local Harbor Freight. I was wondering if someone had one and how well it pulled behind an RT. I also worry about the 8" tires and speed rating. Thats a lot of rotations at 70 mph for thoses little tires.
    RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
    Member of the WSR (Woodstock Spyder Riders)
    Active Member Bumblebee67's Avatar
    Jul 2011
    Heflin,Alabama
    Check with Firefly He built one for his RS. http://www.spyderlovers.com/forums/s.....-got-a-hitch
    Very Active Member hawkiii's Avatar
    Apr 2008
    Northern California
    I like mine. I bought a sheet of rubber a little over 1/4" thick and everywhere metel contacted metal I cut a piece of rubber to place between the metal pieces to minimize noise. Repack the bearings before you try to actually go anywhere though. Tows great, went to Durango with it in June and on our way to Spyders in the Redwoods next week with it.
    Very Happy Spyder Guy
    The GS had over 44,500 miles by March of 2015.
    The F3 is going strong
    Have Spyder...Will Travel
    May 2012
    Quote Originally Posted by hawkiii View Post
    were they 12" tires like fireflys or were they the 8" tire like the original post?
    Senior Member
    Feb 2012
    South Jordan, UT
    55 mph max speed is what the site says...?
    May 2012
    Quote Originally Posted by msj4848 View Post
    that's for the 8" and that's why i was wondering what size tire he had used!
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    I don't see why a bigger wheel couldn't be bolted up... Be careful of a $400 trailer; you're getting exactly what you're paing for! Check everything over about six times just because you know that you paid for the price; not the quality.
    2010 RT A&C ................................. 2014 RT Limited.
    (Both are gone, but not forgotten!)
    Active Member Starrider's Avatar
    Branson, Mo
    The trailer we pull has 8" tires. They hold up real well as long as you don't overload. Pulled mine to TN and back last year, will do it again leaving Saturday.
    Spyder Mods: 23"ultra touring windshield, SpyderAttitude Exhaust, BRP fog Lights, Can Am Wind Deflectors, Kuryakyn ISO Grips, Pyle Amplifier w/wired remote, 4x6 Pioneer Speakers, Amber GlorRyders, Spyderpops Missing Air Dam, Joe Florida Amber Accent lighting, Misty Mountain Sheepskin Seat cushion, Custom Dynamics 4" Risers, Street Magic Highway Footrest Brackets,Spyder Footrests, Spyder Driver Footpegs, Spyder Brake Cover, Spyder Shifter Cover, Can Am Hard Bags
    May 2008
    Bargersville, IN
    I put 12 inch wheels on mine, you have to be sure to get the 4.80 X 12, the larger ones won't fit under the fenders. Took it to Spyderfest with no problems.
    john
    HAPPY SPYDER OWNER
    Dec 2011
    Baltimore Ohio
    Default Cheap trailer
    This trailer is ok for local hauls but long distance with 8 inch wheels you are asking for trouble the tires and bearings one have to keep a real close eye on them. I had one years ago and pulled it out west and replaced the tire after a blow out and than check the wheel bearings and had to replace them also. The smallest wheel to be safe would be 12 or 13 inch. Follow BRP trailer which is a good one.
    Quote Originally Posted by BlueKnight View Post
    Very Active Member rogerb's Avatar
    Jul 2010
    Waterboro,ME
    I have one that I haul behind my RT. If your going to do long rides at Interstate speeds I would recommend 12" wheels. The only thing I would recommend is replace the lights to leds to lower the electrical load on your bike. Harbor Freight has them for around 30$. For the money it is a good deal.
    Jun 2012
    Reno, NV
    I built this a week ago and for the price ($320.00) you can't go wrong.
    Holds more than most MC trailer
    This little trailer was designed for 600 lb loads.
    It has double leaf springs on each side, first thing I did was remove one of the springs and make each side single, this softens things up quit a bit.
    They call for 60 lbs tire pressure, give me a break. If your carrying light loads say under 100 lbs air down to about 7 lbs. heavy loads about 10 lbs.
    Those two things alone now I can pull it empty and it won't bounce around unless you hit a big pot hole.
    -Jimmy
    2012 Spyder RT Limited Lava Bronze / tan seat
    Smoothspyder belt pulley
    KewlMetal LED tail light and fender lights
    Elka front shocks, Stage 1+R
    Prosport digital voltage/clock gauges
    Seal Pup floor boards
    California Scientific Medium Windshield
    Very Active Member Blue Star's Avatar
    May 2010
    Knob Noster, MO.
    I bought the 4 by 4 trailer from Harbor Freight, and bolted on a car-top carrier from Sears to it. The trailer has 12 cinch tires, and you don't even know it is behind you it pulls so good. Had it up to 70 MPH with no problem. I will know more after the trip I am taking next week to SITR.
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    Current bike
    2016 F3-T Audio package.
    Senior Member Ga Blue Knight's Avatar
    Dec 2010
    Augusta Georgia
    Quote Originally Posted by JJW SpyderRider View Post
    The harbor freight 12" wheels have the same bolt pattern. Just remove the fenders and build up some vertical spacers and reinstall or buy metal fenders for 12" wheels. The real issue is the cheap hub bearings. Replace them with quality wheel bearings. I used "Bearingn Buddies" hub bearings as they have a single zerk fitting and you just keep pumping grease until is seeps out of the center. Very simple and easy to do as regular maintenance. Try to keep between 20 to 30 pound weight on the tongue and don't load too much weight in it.
    Mar 2008
    Battle Creek, MI
    Quote Originally Posted by Ga Blue Knight View Post
    Be very careful with the use of Bearing Buddies, especially for long trips at high speed. Trailer hubs need to have air space for expansion of the grease due to heat. Without this space, they can overheat and destroy the bearings, or you can blow the seals, letting the grease leak out and risking a bearing running dry (especially the inboard one). Bearing Buddies are designed to keep water out of boat trailer bearings, and do a good job at that, but they are not a substitute for regular bearing maintenance and repacking, and can cause problems on road trips. If you use them, more frequent inspection of the seals for leakage and inspection for heat build-up on the road is necessary. (Feel the wheel at rest stops.) And don't forget to clean, inspect, and repack the wheel bearings annually...Bearing Buddies or not.
    -Scotty
    2011 Spyder RTS-SM5 (mine) & 2008 Spyder GS-SM5-PE (Nancy's)
    2000 BMW R1100RTP, motorized tricycle & 22 vintage bikes
    Mutant Trikes Forever!
    chickridin
    Guest
    This looks a lot like the Piggy Backer but cheaper and maybe a bit smaller. We have a PB'er w/12" wheels and like it. It pulls great.
    Active Member swrafey2000's Avatar
    Apr 2008
    Lakeland,Fl
    I built my trailer using a old jet ski trailer with 8" wheels.I have towed it behind my pick up but not my bike yet.Am I going to have problems with the smaller wheels?
    VERMONT
    Default 12 INCH WHEEL & TIRE
    I found this Eastern Marine 1-800-453-7379.....they sell the above in a six-ply 4.80 x 12".....no speed rating listed......but if it's a six ply tire I think it must be pretty high.....I will call Monday......Also the price for the combo was $55 ? I think.....Mike.............PS...I think they also had 6 ply...8 " tires....
    Very Active Member flaggerphil's Avatar
    Mar 2012
    Florida Space Coast
    Looks like a car top carrier on wheels...
    Phil
    I may be old, but I got to see all the cool bands.
    2011 Spyder RT-AC
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by flaggerphil View Post
    That is exactly what it is.
    Mine works great.. and is 10% of the price of the BRP one.
    As much as I'd like to have the BRP one... $400 compared to $4,000 is a hard deal not to turn down.....
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM5. Current Spyder ready to tear it up!
