RT-S wiring harness
How long dose it take to install the wiring harness for a 622 trailer and Is there a vidio to show how?
Mod Monster
I installed mine in about 45 minutes. The absolute hardest part is routing the wiring through the back end of the bike. The instructions that come with the kit are really pretty straight forward.
____________________________
Phil - Tyler Texas
2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
It took me and a friend 3-4 hours, including installation of the hitch. Unfortunately we didn't do a video, but you should expect to remove ALL panels from the left side, including the saddlebag.
Keep track of each screw and where it went. I ended up with a sticky latch and had to have my dealer fix it.
Motorbike Professor
That is not necessary! It is not the method in the instructions. Removing the saddlebags is needless.
I don't remember the flat rate time alloted in the instructions, but I did it in less than an hour each time. You do have to take some panels loose on the left side if you want to route the harness internally...which is highly recommended, but the saddlebag can stay in place. Just follow the instructions closely and you will be fine.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Mod Monster
100% agreed.
Phil, Tyler TX- from my iPad3.5 using Tapatalk HD
Phil - Tyler Texas
