Page 1 of 5 12345 LastLast
Results 1 to 25 of 105
    Invalid Emails
    Jun 2012
    Laguna Niguel, CA
    Default RT Vibration continues
    Last time I was at my dealer, they set the belt tension to 615 Neutons and the belt tensioner to 12 lbs. Just got back from a ride to Hollister and the Corbin factory and the vibration is still there at 5400 rpms and again at 6200 rpms.
    Riding on the 101 highway, the 1 highway and the 405 freeway and toll roads, the speeds were 75 mph to 85 mph if I wanted to stay with the flow of traffic. That being said, I was continually dancing in the Vibration Zone.
    BRP is sticking to its guns stating the vibration is normal. I gave them a harsh reply and told them to come into reality. BRP did not respond to my second message. Customer service by the "Ostrich" method
    My dealer understands but cannot violate BRP Policy even though they understand the problem. The dealer told me they could set the tension as I direct but, would have to record the adjustment at my request thus voiding the warrantee.
    Does anyone have any influence with BRP?
    Ride Master
    Jax Beach, Fl.
    Quote Originally Posted by Ride Master View Post
    Ride Master
    I've got to believe everyone riding the RT has the same belt vibration issues and at the same rpms. If everybody has the belt set to factory specifications. I know that I do and I try to get through the vibration zones as quickly as possible. There should be a pulley assembly mounted inside the very long drive belt. To allow tension on the inside upper and lower belt. Which in my opinion would drastically lower this long belt flapping around causing this vibration.
    Oct 2011
    Jacksonville,Ar
    Is the vibration when increasing speed in 5 gear?
    If so shift to 4 gear to pass.
    15 rt , yes Black
    RodMyers
    Guest
    Is that normal?
    I'm having the same issue with my RT.
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by RodMyers View Post
    Is that normal?
    Brp says it is.
    RodMyers
    Guest
    Quote Originally Posted by boborgera View Post
    Brp says it is.
    feels like it's shaking the bike loose
    Jax Beach, Fl.
    I get the belt flapping vibration in 3rd, 4th & 5th gears. I try to accelerate through it as quickly as possible shifting through the gears. I would like to cruise at 75 mph at times in 5th gear. But that is a bad vibration speed for me. My RT starts the belt vibration at 5300 rpm and doesn't stop until after 6200 rpm.
    Texas
    I also have the issue on my 2012 RT. 70-80 MPH. Very annoying. BRP can say what the want, however if this is "normal", they need to go back to the drawing board. I have ridden belt drive Harleys for years and NEVER had this issue.
    Sep 2011
    Waleska, GA
    Default Vibrations
    The only "Good Vibrations" are from my Beach Boys collection.
    I'm not the mechanical geru that some are here, but damned if I'd be riding a bike that has continuing vibrations/harmonic problems like a couple explained above. There's no telling what's being shaken apart in the drivetrain or even in the frame for that matter. I'd sure try working again with the dealer or dealers and BRP to get these situations solved. Something's gonna break or fly apart and then it's really an expensive mess. Transmission or engine repairs sound like they are pretty costly to me.
    Good luck - I think it's time to get as persistant as you can. If the Spyders continue to be driven like that, you'd better have a good "nest egg" to draw from. And then there's the safety angle...
    Tuck
    Feb 2009
    Ceresco, Michigan
    I'm really curious about this. Can any of you with the vibration problems hook up with other RT riders and swap bikes for a short ride to see if you notice a difference?
    Every bike has certain vibration points. You may find that 75 mph can be bad while 77 is fine.. depending on what geat you're in.
    Another thing to consider is road harmonics. There are some roads that I've ridden that just really seem to cause the Spyder to ride with some vibes.
    To the original poster-- BRP can't just 'void your warranty'. They would have to prove that the out-of-spec belt tension that you requested was the direct cause of your problems.
    St. Louis, MO
    Quote Originally Posted by Firefly View Post
    I haven't notice any vibration (especially as described in this thread) when I ryde or am a passenger on our 2012 RT-S. We've only ever shifted at 4,800-5k rpm. I've been in 5th at 68ish mpg up to 75 and haven't felt it feel any different than at 25mph in 1st or 3rd at 40mph. If anyone with this issue is in St. Louis and wants to try ours, PM me. Maybe we can get a ride in, when it isn't 107 degrees
    Mar 2012
    Florida Space Coast
    I haven't had that problem.
    Sacramento, CA
    Default Vibration
    Our 2010 RTS had the vibration at around 5000-5800 RPM. I mounted a Smoothspyder idler and the problem went away. When you accelerate, the bottom of the belt goes slack for a lack of a better word while the top of the belt goes into tension moving the bike down the road. It is the bottom of the belt that is giving you the problems. Look on the home page for Spyderlovers and look for Smoothspyder and get one of his tensioners. The problem goes away!
    Jun 2012
    Michigan
    Ride Master
    We have gotten permission from BRP to go to a tighter belt and are getting very close to solving the vibration problem on this bike. I now have a very small band 62 to 65 mph that has a vibration. Just make your dealer call BRP! Next, the next time you are at your dealer feel the belt tension on a new bike and then go feel yours. The new one will be much tighter and I really do mean a lot tighter, that's the way they come from the factory.
    Good Luck!!
    Jax Beach, Fl.
    It would be nice if BRP resolved this drive belt vibration issue once and for all with the Spyder RT. Then they could get the word out to all the Dealers for a correct fix. I have been riding my Spyder RT below 5,000 rpm and 70 mph. I'm trying to stay out of the severe drive belt flappin/flopping zone. I will not take my spyder out on the interstate. Because I would be riding right in the area of maximum belt flapping zone. Which is 75 to 85 mph and I don't want to take a chance of damaging the engine. Do to excessive belt flopping.
    Palm City Florida
    Quote Originally Posted by flaggerphil View Post
    Me neither.
    Jun 2011
    Donaldson Arkansas
    Quote Originally Posted by A1A View Post
    It would be nice if BRP resolved this drive belt vibration issue once and for all with the Spyder RT. Then they could get all the Dealers on the same page for a proper fix. I ride my Spyder RT staying below 5,000 rpm and 70 mph. I would be afraid to take it out on the interstate. I don't want to take a chance of damaging the engine by going over 5,000 rpm and 70 mph by blending in with traffic flow.
    Will no hurt her, nothing for me to be at 60+ and drop to 3erd and run 9000 and as i am passing, skip 4th and go strait to 5th. feels like the front shocks stretches out as she rockets up front of the pack. They do not like low rpm's. let them sing
    Now as for vibration. yes the belt can and will cause some but there is a bulletton out for another reason for vibration here some info on it.
    http://www.spyderlovers.com/forums/s...ount-Clearance
    Jun 2012
    Michigan
    Quote Originally Posted by Farmboy View Post
    This bulletin is for 2011, mine is a 2012 and there is nothing for the 2012's and it seems many of those complaining have 2012's. By by tightening the belt we have now reduced the vibration to between 4400 to 4900 rpms, IT MAKES NO DIFFERNCE AS TO WHAT GREAR YOU ARE IN!!
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    5000 rpm is my "normal" -- most of my driving is between that and 6000 rpm, sometimes dropping down towards 4000, but I aim my shifting so that I'm drive right around 5000 rpm. The dealership confirmed that this is where the spyder likes to be. You might be getting vibration because you're lugging the engine.
    2015 F3 , Pearl White
    RodMyers
    Guest
    Quote Originally Posted by vondalyn View Post
    Bzzzt. wrong answer.
    happens, for me, to be between 5000 & 5500 rpms
    Jax Beach, Fl.
    I have a 2012 RT SE5, I thought the motor mount shimming issues was fixed for the 2012's? My belt starts really flopping badly at 5300 rpm and doesn't quit this severe flopping until after 6200 rpm. I just can't stand feeling this belt flopping so badly. When I know this is a major issue and needs factory resolution.
    If I get a written garantee from BRP, stating they will fix for free an engine and or drive line problem caused by this floppy belt vibration. Then I'd ride my Spyder RT and ignore the severe drive belt flop.
    Thanks for your constructive feedback though.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    I'm beginning to wonder if this issue is being caused by the revised belts on the 2012s? Just thinking out loud here, but something has changed and that's they only thing I am aware of.
    Feb 2009
    Ceresco, Michigan
    I still think we may have multiple different problems here. Some have stated they're running under 5,000 RPM's when in 4th and 5th....and may be lugging the engine. These Rotax engines like higher RPM's... plain and simple.
    For those that are running in the proper (higher) RPM ranges.. I'm very curious about this problem.
    My 2012 RT A&C doesn't vibrate... it's far smoother than my GS was-- and that had the belt tensioner installed.
    I wasn't aware that the belt had been updated for the 2012 RT's ??? Anyone have more info on this?
    If that's the case.... I'll have to sell my spare belt I've had for a year or so.....
    Thus far, my only complaint about the RT belt is the noise during acceleration.....
    Jun 2012
    Michigan
    I would be happy to trade my vibration for your noise, mine makes no noise of any-kind!
    Jun 2012
    Clemmons, NC
    Unhappy Yeah well
    Its the belt tension and we either complain as a whole so they come up with a tensioner recall or pay out of pocket for one. Definitely seems to be the answer because of belt vibration in between 5000-6000 RPM.
    Some of these issues really hurt my impressions of BRP especially coming from a Gold Wing.
