Results 1 to 17 of 17
    Senior Moment
    May 2008
    mansfield, pennsylvania
    Default windshield help?
    I have a 2012 RSS.. I installed the big touring windshield from BRP,, Well It makes my head bobble really bad.. So I took it off and installed the stock winshield,, Its a little better but my wife really complained and I would like something better.. I am 6 foot 2 and ride fairly straight ip postion.. Any ideas out there..
    Dec 2011
    Columbia county NY
    I run this some of the time on my OEM shield....it's a Laminar Lip, small (I believe).
    It deflects most of the wind up & over the top of my helmet and there is very little buffeting. I'm 6' 5" so it may even work a little better for you.
    Oops! Forgot the pic!
    Active Member Recluze's Avatar
    Jan 2009
    St george, UT
    I have been through a lot of windshields on RS's. Todays answer for me a is a large BRP touring windhsield and Madstadt bracket to customize the fit so it is just right for my riding style.
    http://bobspyder.wordpress.com/
    #610 2007-2009
    #104 2012....
    Senior Moment
    May 2008
    Quote Originally Posted by dannymax View Post
    How do you install it looks like you drill holes in stock is that correct.
    Invalid Emails
    Oct 2011
    Glennville, Ga
    I recently instfalled the Cee Bailey, 23" on my RS. I have been riding for over a year with the stock windshied. The CB worked fine until I increased my speed to 65 or 70. The bobble effect was really bad. I am wondering if I shoud have ordered a shorter (21") It makes me want to put my stock back on the machine. Just wondering, is this bobble head thing a result of a windshield that is to tall??
    Default WINDSHIELDS
    I made mine from a gold wing 1500 blank....it's now 24.5 inches tall & 23 in.wide at top & 30 in wide at bottom with 650 sq in coverage....it attaches to the handle bars and is set at a 44 degree angle (rake) . I don't notice any handling or buffeting differences wether the Spyder is going 65 mph or 115 mph.......(not on a public highway)........Mike.............So make your own it was pretty easy and only about $125
    Dec 2011
    Columbia county NY
    Quote Originally Posted by Jimmy Neutron View Post
    No, those are little 3M sticky hook/loop things....or whatever they're called. Kinda like velcro but all hooks.
    Invalid Emails
    Oct 2007
    Gold Coast Australia
    Quote Originally Posted by Recluze View Post
    I believe its not just the height of the screen. You need to eliminate the negative pressure that causes turbulence off the top of the screen. Any screen fixed flush to the Spyder bodywork will tend to do that . This is one of the main reasons the Madstad screen works so well.
    May 2011
    USA
    For me the answer was a 21" Madstad -and- the BRP side deflectors. The windshield eliminates about 60% of the wind and the side deflectors about another 30%. It took both to do the job.
    Aug 2010
    New York
    Call Madstad and talk to the owner, he will set you up with what you need. I too had helmet buffering badly and the Madstad solution resolved it. Look at their web site. There needs to be a space between the windshield and the dash.
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    I have the Madstad 21" also and I'm 6'1". No buffeting at all.
    Alignment Specialist
    Aug 2008
    MD
    Madstad, Madstad, Madstad...there is no other option in this discussion...the best shield for any person, hands down. You can go 20, 22, or 24 inches...you can adjust it any which way you want.
    Talk with Mark or Patty....they are incredibly helpful...
    Senior Moment
    May 2008
    Quote Originally Posted by bone crusher View Post
    Thanks I will get a hold of them today
    Jun 2012
    Central Texas USA
    Check out CalSci windshields. They have a hole in them to reduce turbulence.
    http://www.calsci.com/motorcycleinfo/Spyderprod.html
    Jul 2011
    Mount Airy,Ga.
    Quote Originally Posted by donec View Post
    This is what I posted on Monday 26,2012:
    The UPS guy delivered my Cal Sci windshield today. I took my sport/touring windshield off my 2011 RS-S and pack it away for the winter. I unpacked the windshield and it did not fit due to it was not finished. The sides was loaded with some heavy tool marks and not squared off. Tomorrow I'll waste a day finishing and fitting. But I am going to leave the tool marks and rough edges to show everyone what poor quality work Cal Sci did for me.
    On the hazy look. My BRP sport/touring windshield is clearer than the Cal Sci. I knew that before I order my Cal Sci windshield, because it just for winter riding.
    Mike
    This how all the edges look.
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default MAKE ONE
    MAKE YOUR OWN WINDSHIELD....
    i bought a $20 piece of Lexan from HOME DEPOT, and with a heat-gun, Skill saw and some time, i came up with this, see pix... i'm 6' 2" and have no issues with bufferting... the little air management 'winglet' (pic #3) at the top took care of that...
    arntufun
    Guest
    People forget full face helmets already have windshields. Adding a windshield on your Spyder is redundant !!!!!!!
