Originally Posted by BajaRon
Dry Sump:
. Foam does not lubricate.
Oh, really? Sorry, I could not resist.
Dry Sump:
This is a good thing to have in a motorcycle. Among other things it allows the engine to be lowered 2 or 3 inches giving you a lower center of gravity and lower tank/seat hight. There are downsides to every option and having an oil reservoir that needs to have the engine run to get accurate oil level is minor compared to the advantages.
Foam:
Different oils will have varying amounts of foam. High RPM engines, wet clutches and transmission gears tend to create more foam than other engine types.
I use Amsoil and there is so little foam (regardless of when you check) that it is hard to tell if there is any at all. Some oils foam a lot. Because it is difficult to get an accurate level reading when the oil is foamed you should wait until the foam dissipates.
Of course foam is not a good thing to have circulating in the pressurized circuit of any engine. Though it is highly unlikely that any of the foam in the top of your oil reservoir will reach the oil pump, it is not a bad idea to use an oil that resists foaming, especially in an engine where the oil also lubricates the transmission gears (as in our Spyders). Foam does not lubricate.
I use BRP oil. That's all the dealer puts in. I'll wait awhile for the foam to dissipate when checking level.
USAF '69-'89 E7
Thailand/Vietnam 1972
USAF '69-'89 E7
GOS member (Girls On Spyders)
Get back to girls on spyders where you belong. This is the mechanics forum.
USAF '69-'89 E7
Hey, I am sorry about my post, i should have said you will have to buy 5 quarts, after you are all wraped up you will have a 1/2 quart left over, to put in at about 2000 miles down the road.
SpyderLovers Sponsor
Dealers will put in whatever you tell them to put in, as long as it meets or exceeds manufacturer's specs.
