What's your front shock setting?
We got our shift selinoid replaced and we are back on the road with 265 miles on it... with a new question.
What is your ideal setting for the front coil shocks?
Mine is set at "3", and I weigh about 200lbs. It seems like it leans a little too much on the curves at 70mph. Those curves make me feel uneasy. I adjusted it to "5" and it cut down on the lean, but it was rough riding. Suggestions? or is it just getting used to it?
AND THANK YOU to whomever brought up the extended warranty deal they have going. I talked to my dealer while it was in the shop and he got me the extended warranty for NOTHING... maybe he was trying to make up for having it in the shop one week after i got it...
John
Motorbike Professor
It is a bit of a personal thing. Try #4 for a compromise...it costs nothing to change.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
3 was too soft, 5 was too harsh....I settled on 4, not an exact science, but works for us.
2011 Spyder RT A&C SE5
Thinks out loud
5 and wish there was a 6.
Mine is set at 5. Much better.
Double Ditto--or how about a 10!
Switched from 3 to 4 about 2 weeks ago. Like it better than at 3. Turns are more precise feeling at 4 for me. So far so good.
David
2012 Spyder RTS SE5 - Sold
Ours are at 5 and can't wait for my ELKA's. Saving now and will be getting them installed at Spyderfest next year.
I have my RS at 5, did I mention I have RT shoks in my RS
4 here... a pretty good compromise setting! 18 psi in the tires too...
Shock Setting
When I had the oem tires on my 2010 RT had the shocks set at 5 and did great but when I put the Falcan on the front set back to 4 for it was to hard a ride. This setting is working out good for me.
John
magical member
"Draco dormiens nunquam titillandus"
My Rides;
Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
Favorite Ride;
Nimbus 2000 boy this thing can fly.
Mods:
Charm of invisibility, Reparo Charm (cuts down on service cost)
One always wonders about roads not taken.
I had mine set on 5, but I just installed my new stage 1+ Elkas that are set to 25 from the factory. I haven't taken my spyder out for a test run yet, but I have 50 settings for adjustment now instead of only 5. I hope I can find a good setting that won't be too harsh or too soft. I want it just right.
Be careful not to confuse the stocks 5 adjustment settings with the 40 settings of adjustment on your Elka's.
The 5 settings on the stock shocks only change the preload that you are applying to the spring rate. Setting it to 5 applies more load on the spring to stiffen the spring rate. Setting it to 1 will do the opposite and make it really soft...almost too soft.
The preload on the Elka shocks are controlled by the red anodized ring at the top of the spring, but the black knob at the bottom controls your rebound dampening.
In essence, not only are you able to make finer adjustments with your preload since the preload ring is on a threaded body, but you can now play with the rebound reaction on the shocks by using the black knob.
Sounds confusing? I know...but, I am here to help in any way I can, so please dont hesitate to contact me at 1-8200-557-0552 ext 257 if you need more clarification. I am always more than happy to talk to you folks over the phone.
Regards,
John @ Elka
I had the stock shocks on my 2010 RT set on 5 but when I changed to the 2011 shocks, 5 was a little too stiff and made it bouncy in the corners so I had to go back to position 4. Wish I had Elkas or something with adjustable rebound so I could go to a stiffer pre-load and try to control the bounce with more rebound damping.
Cotton
John, I'm glad that you showed up here; I've got a question about the proper shock application for a 2010 RT...
I see all sorts of reservoirs, damping, rebound, preload...
Which shock would you suggest for somebody who's kind of happy with the stockers, but knows that the Elkas would offer better control of that heavy front end?
Thanks!
Thanks!
Stage 1+.
Honestly, it's the best bang for your buck. It gives you preload adjustment and rebound dampening which is perfect for the vast majority of RT riders.
Will you be at Spyders in the Adirondacks?
Thinks out loud
John
Hi John I found the same problem with my RT I tried different settings on my shocks but couldn't get it stop dipping into corners so I fitted a new swaybar and it fixed the problem try this website
http://www.wespydservices.com/#!
I think it would help you
My will reads "being of sound mind and body,
I spent it, go make your own!"
VERY HAPPY SPYDER OWNER.
GOS member (Girls On Spyders)
Tri-Axis Handle Bars
Drift HD 720 digital video camera w/ remote
Russell Day-Long Custom Seat and Driver backrest
BajaRon Swaybar
Elka Stage 1 Plus Shocks
Original Grip Buddies
Seal Floorboards DLX
Two Brothers Exhaust
GloRyders with remote
Zumo 660 GPS
2011 RTS SE5
Waitng.....waiting.......waiting.
ordered mine around the first......don't mind waiting in line for something that works.
Now, hurry up.......OK
Don't hold your breath...I ordered mine on 6/20, still waiting.....it's "SHOCKing"
