Results 1 to 24 of 24
    Detroit, MI
    Cool What's your front shock setting?
    We got our shift selinoid replaced and we are back on the road with 265 miles on it... with a new question.
    What is your ideal setting for the front coil shocks?
    Mine is set at "3", and I weigh about 200lbs. It seems like it leans a little too much on the curves at 70mph. Those curves make me feel uneasy. I adjusted it to "5" and it cut down on the lean, but it was rough riding. Suggestions? or is it just getting used to it?
    AND THANK YOU to whomever brought up the extended warranty deal they have going. I talked to my dealer while it was in the shop and he got me the extended warranty for NOTHING... maybe he was trying to make up for having it in the shop one week after i got it...
    John
    I have mine set at 5 on both RT's.
    Mar 2008
    Allegan, MI
    It is a bit of a personal thing. Try #4 for a compromise...it costs nothing to change.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Active Member Dib52's Avatar
    Mar 2012
    Wylie, Texas
    3 was too soft, 5 was too harsh....I settled on 4, not an exact science, but works for us.
    2011 Spyder RT A&C SE5
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    5 and wish there was a 6.
    Invalid Emails
    Apr 2012
    Tennessee
    Mine is set at 5. Much better.
    Registered Users flybuddy's Avatar
    May 2012
    Fort Myers
    Quote Originally Posted by Jerbear View Post
    Double Ditto--or how about a 10!
    2012 Spyder RT
    Registered Users cdavid's Avatar
    May 2012
    Waterville, OH
    Switched from 3 to 4 about 2 weeks ago. Like it better than at 3. Turns are more precise feeling at 4 for me. So far so good.
    David
    2012 Spyder RTS SE5 - Sold
    Hanover, PA
    Ours are at 5 and can't wait for my ELKA's. Saving now and will be getting them installed at Spyderfest next year.
    Aug 2010
    puerto rico
    I have my RS at 5, did I mention I have RT shoks in my RS
    4 here... a pretty good compromise setting! 18 psi in the tires too...
    Dec 2011
    Baltimore Ohio
    Default Shock Setting
    When I had the oem tires on my 2010 RT had the shocks set at 5 and did great but when I put the Falcan on the front set back to 4 for it was to hard a ride. This setting is working out good for me.
    Quote Originally Posted by Jcan View Post
    John
    magical member harrypottar's Avatar
    May 2012
    Bellingham MA
    Quote Originally Posted by Dib52 View Post
    "Draco dormiens nunquam titillandus"
    My Rides;
    Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
    Favorite Ride;
    Nimbus 2000 boy this thing can fly.
    Mods:
    Charm of invisibility, Reparo Charm (cuts down on service cost)
    One always wonders about roads not taken.
    Registered Users bo9roadking's Avatar
    Apr 2012
    San Antonio, TX
    I had mine set on 5, but I just installed my new stage 1+ Elkas that are set to 25 from the factory. I haven't taken my spyder out for a test run yet, but I have 50 settings for adjustment now instead of only 5. I hope I can find a good setting that won't be too harsh or too soft. I want it just right.
    Oct 2010
    Montreal, Canada
    Quote Originally Posted by bo9roadking View Post
    Be careful not to confuse the stocks 5 adjustment settings with the 40 settings of adjustment on your Elka's.
    The 5 settings on the stock shocks only change the preload that you are applying to the spring rate. Setting it to 5 applies more load on the spring to stiffen the spring rate. Setting it to 1 will do the opposite and make it really soft...almost too soft.
    The preload on the Elka shocks are controlled by the red anodized ring at the top of the spring, but the black knob at the bottom controls your rebound dampening.
    In essence, not only are you able to make finer adjustments with your preload since the preload ring is on a threaded body, but you can now play with the rebound reaction on the shocks by using the black knob.
    Sounds confusing? I know...but, I am here to help in any way I can, so please dont hesitate to contact me at 1-8200-557-0552 ext 257 if you need more clarification. I am always more than happy to talk to you folks over the phone.
    Regards,
    John @ Elka
    Invalid Emails
    Sep 2009
    west Texas
    I had the stock shocks on my 2010 RT set on 5 but when I changed to the 2011 shocks, 5 was a little too stiff and made it bouncy in the corners so I had to go back to position 4. Wish I had Elkas or something with adjustable rebound so I could go to a stiffer pre-load and try to control the bounce with more rebound damping.
    Cotton
    Quote Originally Posted by Trooper View Post
    John, I'm glad that you showed up here; I've got a question about the proper shock application for a 2010 RT...
    I see all sorts of reservoirs, damping, rebound, preload...
    Which shock would you suggest for somebody who's kind of happy with the stockers, but knows that the Elkas would offer better control of that heavy front end?
    Thanks!
    Oct 2010
    Montreal, Canada
    Thanks!
    Stage 1+.
    Honestly, it's the best bang for your buck. It gives you preload adjustment and rebound dampening which is perfect for the vast majority of RT riders.
    Will you be at Spyders in the Adirondacks?
    Well I sure would LIKE to be!
    The negotiations between me and the Missus have pretty much deteriorated into a running knife-fight...
    If I can shake loose, it might be for a late-Friday run up the Northway to meet you guys somewhere...
    Apr 2012
    Stage 1+.
    Waitng.....waiting.......waiting.
    ordered mine around the first......don't mind waiting in line for something that works.
    Now, hurry up.......OK
    Oct 2010
    Montreal, Canada
    Well, I dont build them, but the guys in production do kinda run when I go back there since Spyderfest.
    Active Member wtwing15's Avatar
    Aug 2008
    Canberra ACT Australia
    Thumbs up
    John
    Hi John I found the same problem with my RT I tried different settings on my shocks but couldn't get it stop dipping into corners so I fitted a new swaybar and it fixed the problem try this website
    http://www.wespydservices.com/#!
    I think it would help you
    My will reads "being of sound mind and body,
    I spent it, go make your own!"
    VERY HAPPY SPYDER OWNER.
    GOS member (Girls On Spyders) Flight Risk's Avatar
    Feb 2012
    Garland, TX
    Had my Elka Stage 1 plus set at 25 ..... They are fantastic. The Spring??? is 325lbs......I weigh 150 but often have a rider on the back. It works great!!
    Tri-Axis Handle Bars
    Drift HD 720 digital video camera w/ remote
    Russell Day-Long Custom Seat and Driver backrest
    BajaRon Swaybar
    Elka Stage 1 Plus Shocks
    Original Grip Buddies
    Seal Floorboards DLX
    Two Brothers Exhaust
    GloRyders with remote
    Zumo 660 GPS
    2011 RTS SE5
    May 2012
    Fort Myers
    Don't hold your breath...I ordered mine on 6/20, still waiting.....it's "SHOCKing"
    2012 Spyder RT
