Here we go.....AGAIN
Yep, another dead battery. I hate to say it, but this crap is getting old. Battery tender on the whole time I was gone this trip and came home to a dead Spyder. Oh well, you would think I am used to it by now.
Originally Posted by Rattigan_Roger
Yes there are issues there.
I think the radio is the culprit.
Wasn't there a bulletin on the radio module drawing down the battery.??
[QUOTE=boborgera;479746]Wasn't there a bulletin on the radio module drawing down the battery.??[/QUOTE
Radio module was replaced about 3 months ago, so that apparently didnt fix the issues.
Off to the dealer she went. Very glad I have a good dealer and service department so close.
I need a decal that reads " If you see this Spyder on a trailer, call BRP. Its another dead battery issue"
Just a thought if you pull the ground wire off battery and hook a 12volt bulb(1156 taillite) between the ground on battery one side of bulb and the other side of bulb to frame. if bulb burns even if a little you have a draw. you can then pull fueses out one at a time and when you pull one that stops the lite from burning you will know what circute is the problem i.e radio,lights,ectect..... you will need a 1156 tail light bub and a scoket with wires to put in line with battery. I know how y'all feel about having troubles with spydres(BOY DO I). I worked in electronics for several years and this was how we could work on equiptment with burning something up Pete
my wife and I on our 2011 spyder-rt-L'IL Red
I soldered two wires on a 1157 with alligator clips on the other ends, Used that as a timing light for my air cooled Beetles, [70's] Now i just use it as a test light.
I Feel Your Pain
As of Wednesday it will be 3 weeks that Cowtown has had my Spyder and that is exactly how it all started.
You might try pulling the fuse for the radio and assc. I started throwing 1614s after a couple dead batteries, but everyone thinks I'm just gitting all of the crap at once and that nothing is related. I hope they are right, If you start getting codes please holler!!!!
Most battery tenders I'm familiar with for motorcycles put out either 0.9 amps or 1.1 amps. If that couldn't keep up with your drain, that's one significant drain. Doesn't sound like the small current drain reported with the radios.
I had the radio replaced today. The water intrusion comes in thru the antenna lead. My antenna junction was totally corroded inside and actually broke off when they pulled it apart. I asked what they do to prevent that happening again and they said they're supposed to shrink wrap the antenna connection. So if your dealer replaced the radio thinking that was the cause and didn't do the shrink wrap, it could be acting up again. But as I said, a one-amp drain is much more than reported for the radios. Keep us posted.
RT and Gold Wing States & Provinces
Spyder is ready for pick-up. The cause of the battery drain.......UNKNOWN.
The shop CAN-NOT figure out what the issue is.
Looks like I might go on the monthly BRP. aka battery replacement plan
Can anybody say WTF!!!!!!!!!!!!!!!!!!!!!!!!!!
Thinks out loud
Looks like I might go on the monthly battery replacement plan.
Check it yourself. It may be sporadic.
I was out on a ride and stopped for awhile. Went to get bake on the rode and nothing. No juice for anything. Thought it was the battery and found someone with a charger. Had it on for an hour and still nothing. So everyone thought the battery was dead. Went and spent $139.00 for a new battery. Put it in and still nothing. A Harley guy was looking it over and spotted a tiny burn mark on the ground connection on the right side. Tapped the connection and was very loose. Tightened it up and the Spyder fired right up. Now I have an extra battery as it couldn't be returned as it was electrical. Check the ground under the seat on the right to see if it's loose. Good luck.
Life should NOT be journey to grave with intention of arriving safely in attractive and well-preserved body, but rather you skid in sideways on 1 leg with body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!"
Thanks for the idea. All have been checked, tightened, tested over and over again. Its a mystery for which there is no answer.......
Love the 3 wheels way of life
2011 RT Limited
Mods
Custom vinyl wrap
Two brothers exhaust
custom glo riders
carbon fiber dash kit(orange)
2013 15 inch wheels powder coated orange
all factory castings powder coated orange
Elka's
Baha Ron sway bar(will be powder coated orange next winter)
Spyder pops (every thing he has for the rt)
Lamonts hiway pegs
