Results 1 to 25 of 29
    Registered Users Spyderific's Avatar
    Jun 2012
    Alberta
    Question 3 wheel only license in Alberta
    My wife recently took and passed her motorcycle license in Alberta. While finishing the test with the examiner he told her that because she did the road test on a Spyder she is restricted to 3 wheeled vehicles only. She has contacted the Alberta government to verify this restriction but has not heard back. Has anyone else had this restriction imposed on their license? Does this mean those of us with existing motorcycle licenses are not allowed to drive a 3 wheeled vehicle?
    2012 RT Limited (White)
    Tricled fenderz, 3rd and 4th brake lights, mirror mounted rear signals and tip lights. HID head and fog lights. Smooth Spyder. Bajaron Swaybar
    Active Member Outporter's Avatar
    Nov 2011
    Bay Roberts, NL, Canada
    Not sure about Alberta but here is how it works in Ontario (simplified version).
    If you currently hold a motorcycle licence (M2 or M) you can ride a 3 wheel motorcycle with no other testing required. If you are going for your motorcycle licence for the first time and you take your driving test on a 3 wheel motorcycle then you are issued a restricted licence (ML, I think) and can only ride a 3 wheel motorcycle. If you want to ride a 2 wheel motorcycle you must take your driving test on a 2 wheel motorcycle in which case you will be issued an M2 licence, upgradeable to an M after a period of time.
    Cape Spear, NF. Most
    easterly point in North
    America
    Provinces & States visited on
    Motorcycle
    2 and/or 3 wheel
    Registered Users JJW SpyderRider's Avatar
    Jun 2010
    Rockton, IL
    Quote Originally Posted by Spyderific View Post
    Works the same way here in Illinois. 3-wheelers can take the test, even show a RS in our DMV manuals, but can then only ride with 3 wheels. I took the MSF class on a 250cc two wheeler but can ride both 2 and 3 wheelers. Well at least I'm qualified to ride a 2 wheeler in a parking lot.
    RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
    Member of the WSR (Woodstock Spyder Riders)
    Registered Users Heliplt's Avatar
    Apr 2011
    Hood Canal WA
    Washington State has separate license for 2 wheels and 3 wheels. You have to have one of each in order to ride both.
    Absorb what is useful, use no limitation as limitation
    Member Spydergrrl's Avatar
    Apr 2012
    Chilliwack, BC
    Default BC Similar to Alberta
    Hi,
    I just finished the process here on a Spyder. You can do all the testing on the Spyder (motorcycle skills test, then road test), and they told me it would be a class 6R - motorcycle license restricted to 3 wheels.
    But in fact when I got the actual license in the mail, it says class 6(also class 5, which is regular vehicles) , and has a line that says "Endorsements/Restrictions:", but there is nothing listed there. So, I'm not sure they have an actual category for the three-wheeled vehicles.
    Interesting to see what the rules are in different places.
    Liz
    Active Member BlueKnight's Avatar
    Feb 2011
    Hamburg, New York
    In New York, if you take the road test on a two wheeler your good for any type of motorcycle, but if you take the road test on a three wheeler you are only licensed to ride a three wheeler.
    Same situation in Alaska. If you take your drivers test on 3 wheels you will be limited to 3 wheel operation only. If you take the drivers test on two wheels you can drive either type of motorcycle.
    Very Active Member Oldmanzues's Avatar
    Mar 2009
    Beavercreek, Ohio
    Ohio, same deal
    Oldmanzues
    Very Happy Spyder Owner
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by Outporter View Post
    In Ontario...you take your driving test on a 3 wheel motorcycle then you are issued a restricted licence (ML, I think) and can only ride a 3 wheel motorcycle. .
    Its a Class MM licence for 3 wheeled vehicles.
    ML is "Limited Speed" for two-wheeled vehicles that cannot maintain a speed gretaer than 80 Kmh. Like smaller scooters. They are restricted from travelling roads with posted speeds greater than 80 Kph.
    Active Member CMA Cowboy's Avatar
    Waynesville, Missouri
    Missouri is the same. Good recomendation is to take the MSF course so you understand how a bike works and then you can ride 2 or 3 wheel.
    Ray
    "Instead of arriving in Heaven in a nice well perserved body I'd rather slide in feet first, all beat up, loudly proclaiming thank you Jesus for a great ride!"
    Very Active Member jvicker's Avatar
    May 2009
    Appleton, WI
    Default Wisconsin
    Took my test on the spyder and I am restricted to 3 wheeled cycles. Darn
    Very Happy '08 Spyder RS Owner
    Apr 2011
    GREENVILLE, SC
    Default SOCAR LICENSE
    here in South Carolina, all you need to operate a SPYD3R or any other 3 wheeled vehicle, is a regular drivers license... this includes 2 wheelers with a side car.... if you're riding on just 2 wheels, you need to take the motorcycles driving test... both written and road test...
    Invalid Emails
    Alberta, Canada
    Did you hear back from the Alberta Gov. on this?
    Active Member waytootall67's Avatar
    May 2011
    Calgary, Alberta, Canada
    Took mine in Calgary and mine reads class 5/6 three wheel motorcycles only.
    Registered Users spyderrock's Avatar
    Apr 2011
    Alberta,Canada
    Hey Spyderific in Alberta if you take your test on a Spyder or other trike you are limited to only driving a trike, the license should have a letter "B" beside it. If you take your test on two wheels you can drive any motorcycle. Where are you guys I live in Sherwood Park.
    Love the 3 wheels way of life
    2011 RT Limited
    Mods
    Custom vinyl wrap
    Two brothers exhaust
    custom glo riders
    carbon fiber dash kit(orange)
    2013 15 inch wheels powder coated orange
    all factory castings powder coated orange
    Elka's
    Baha Ron sway bar(will be powder coated orange next winter)
    Spyder pops (every thing he has for the rt)
    Lamonts hiway pegs
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Also in BC if you take your road test on Can Am Spyder you are restricted to that if you take it on two wheels you can ride anything
    Invalid Emails
    Oct 2015
    Deland, FL
    Default Florida
    A three wheel and regular. Regular can ride either, three wheel can only ride 3 wheels.
    Jun 2015
    Ritzville, Wa
    Default The only exception
    Quote Originally Posted by Heliplt View Post
    There is one exception. If you are operating a 3 wheeled vehicle, controlled by a steering wheel (think Slingshot) you don't need an endorsement.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Active Member _..stiffler..'s Avatar
    Feb 2015
    NB Canada
    In Alberta it works the same as above.
    3 wheeled can only drive 3 wheeled.
    2 wheeled can drive 3 or 2 wheeled.
    What you do the test on is what your restricted to.
    Sent on Note 5 in Taptalk
    2011 RT Limited , White
    Member Lizzerd's Avatar
    Jul 2016
    Calgary Alberta Canada
    Default Alberta licensing
    took my road test 7/29 and passed; the registry office had never heard of a restriction on the type of Class 6 license ...
    Liz / Calgary
    2016 F3-T, shorty mods only
    2016 F3-T , black
    May 2016
    No not true if you take road test on Spyder yes you are restricted to s three wheel if already have a motorcycle lic you can ride three wheeler bike
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    Quote Originally Posted by BlueKnight View Post
    Ditto in Ohio.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Jun 2015
    Ritzville, Wa
    Default How did you manage that?
    Quote Originally Posted by spyderrock View Post
    Looking at your travel map, how did you manage to miss Nevada? You hit every state, north, south, east and west of it.
    Greg Kamer
    Feb 2018
    Edmonton
    Quote Originally Posted by gkamer View Post
    Hey guys an update, here in Calgary/Alberta other day did my beginner bike test and lady said at course if you do course and Rd test on spyder it will be a 6 b as other member stated and can only ride 3 wheel bikes period, class 6 is good for both, that was on May 21st 2018, thx
    Sep 2016
    Parma, Idaho
    Default Qualifying Driver's Licenses
    Idaho stipulates that those that have a license for conventional motorcycles, can ride both those and three wheelers. However, those having taken the MSF course on a three wheeler, can only only ride a three wheeler.
