Page 1 of 2 12 LastLast
Results 1 to 25 of 40
    Registered Users StSpyder09's Avatar
    Aug 2008
    PENSACOLA, FLORIDA
    Exclamation PLEASE HELP! Spyder broke down just outside of Nasville, on my way to Memphis
    Hi all. Traveling to Memphis, on my way from Ohio. Spyder went into limp mode, engine light and dps all came on and Spyder stopped. Its after 7:00 pm. Does anyone have any suggestions for fix to get to Memphis. Or to complete the trip back home to Pensacola?
    St'09
    Dec 2008
    Syracuse, NY
    Check to make sure the relays and fuses are all seated and check the battery connections.
    Active Member madozier's Avatar
    Oct 2008
    Tupelo, Ms
    If everything checks out. Have you tried to clear the codes by turning the key on and off three times?
    Happy Spyder owner
    Mark
    Aug 2008
    PENSACOLA, FLORIDA
    Quote Originally Posted by wyliec View Post
    OK, going to do that now. Thanks!
    Then I'll try the code clear process. Thanks!
    St'09
    Very Active Member bullant12's Avatar
    Oct 2010
    Somewhere out there...
    On the way to Memphis:
    Carlock Powersports
    57-B Carriage House Jackson TN 38305
    Phone: 731-410-8822 Fax: 731-410-8821
    Toll Free Phone: 866-761-2110
    Last edited by bullant12; 07-03-2012 at 09:13 PM. Reason: Removed Previous Dealer comment
    May all your encounters with the law begin with the words: "nice trike!".[/B]
    2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
    Previously owned:
    2010 Can-Am Spyder RT SM-5
    2011 Can-Am Spyder RS-S SM-5
    2013 Can-Am Spyder RT-S SM-5
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by Mr Orange View Post
    I'm sure an RT owner will chime in with more info on this. Good luck with this and keep us informed.
    He doesn't have an RT.
    Clarksville, TN
    Quote Originally Posted by StSpyder09 View Post
    Americas Motor Sports in Nashville has Spyders... just depends on where you are... with tomorrow being July 4th, they might be closed.....
    Aug 2008
    PENSACOLA, FLORIDA
    I just reallized that and added to my post.
    Thanks to all of you. I did all as suggested. Its dark now and I'm at the ER. So if they allow, I'm staying till daylight. Then I will see if it all worked. Any other suggestions are totally appreciated!
    St'09
    Registered Users Tierhog's Avatar
    Jan 2012
    Modesto, Ca
    What code came up?
    Registered Users Farmboy's Avatar
    Jun 2011
    Donaldson Arkansas
    I am so sorry that i would not be of any help... our spyders are the only bikes in the world that will shut us down in the middle of no where with a "LIMP MODE".
    Never in all my live I have ever owned a bike that has broken down till I tried a spyder... But I love them... They just got to get rid of them damm computers !!! GIVE ME JAPAN OR USA COMPUTERS or BUST!!! harsh ain't it??? ask me or any other spyder owners that have been on the side of a high way in 100+ deg. heat if we give a hoot about BRP's "glorified safety computers". Too many similar situations like this are happening to all Including my wife and I.
    Hot Wheels loves to ROCK!
    Jun 2010
    Memphis, TN
    I don't know if they are the same for the rs and RT but I have a set of RT relays and lots of tools. I sent you a PM with my phone number.
    Aug 2008
    PENSACOLA, FLORIDA
    Quote Originally Posted by Tierhog View Post
    What code came up?
    I haven't done the code search yet. Gonna wait til light and get on the road, when/if it happens again I will do the code search process.
    When it went into limp mode, I saw the Hospital sign and thought (safehouse). So here I'll stay til first light. I decided to attempt to top Orange's record and limp home to Pensacola. At least I'll be on my way home. Really wanted to make the reunion, but too many variables lead to a second trip back up to retrieve the Spyder or an even longer trip with uncertanty looming. I will def. Stay in contact with you all for advice and support. Thanks again.
    St'09
    Very Active Member napper39's Avatar
    Jul 2010
    kansas ottawa
    those relays will make that hapen,so rember you can buy those at any auto parts store,i dont know the number off hand but if you take one out and show it to the clerk he can cross reverance and get the right one for youe bike.then just try the new one in till you find the right one thats bad or get all new ones and change them all out.another thing i was alwas told to reset the competer you should take the key out then walk a few steps away from the bike waght 5 to 10 min then try to start it up every thing should be reset.now this is the way ive done it and it works fine.the battery cable is it tight.hope this helps . heres a number off mine vj28-95f24-so1 that number is on the top this number is on the side mmm,,mex0621312b
    Aug 2008
    PENSACOLA, FLORIDA
    With any luck just shutting down and removing the key for a few minutes will allow you to restart and continue on. When I had my adventure with this I was able to restart after every limp mode. I kept going into limp mode every 25-35 mile for the 200 miles or so but I was able to make forward progress. If you get going and it occurs again you might want to try and retrieve the code by doing a "mode-set-turn signal switch activation". I'm sure an RT owner will chime in with more info on this. Good luck with this and keep us informed.
    I just read your profile and found out you have an RS. Codes on an RS are by getting it to display Total Hours, then flash the headlights either 3 or 5 times and then the codes should scroll across the screen. The code has to be active so don't shut the bike off. Get the code first.
    So what was the issue in the end? It does restart. How will having the codes help me? I've got twice your distance to Pensacola, but I have to try. Thanks again.
    St'09
    Aug 2008
    PENSACOLA, FLORIDA
    I take it from your last post after you reset you didn't get another limp mode. I had about 6 of them and then the last ~130 or so miles were limp free including the trip down to the dealer the next day. I also was lucky to have another pair of Spyderlovers with me. We had figured out that it was some sort of problem with my brake lights. It ended up being just the micro-switches which for some reason needed to be adjusted. If you are going to be in the New Orleans area I can recommend a dealer in Houma, LA. They had me back on the road quickly. Travel safely and good luck.
    The dealer is:
    Performance Powersports
    1816 Martin Luther King Blvd.
    1-985-876-7610
    Thanks Napper. Will check that too if neccessary. Mr Orange you may have hit it on the head. Just last week I replaced my LED break lights, cause the right one kept blinking off and on. I noticed the replacement is out now on the same side. It blinks if I tap the casing. I figured I would replace again once I got to Memphis. Did not know this could affect the whole system. Can a user easily make the adjustment you spoke of?
    St'09
    Please keep us posted. I cannot add any additional advice, but hope to hear a good outcome.
    Oct 2008
    Tupelo, Ms
    Yeah, early on failed brake lights were causing issues and the replacement bulbs along with fuses and relays became part of the list of parts many were carrying on long trips. That is more than likely your problem.
    Happy Spyder owner
    Mark
    SpyderLovers Sponsor SPYDERPOPS's Avatar
    Oct 2007
    Pearcy, AR
    The tail lights could be the problem for sure. If one is bad then there may not be enough draw for the computer to recognize the brake lights are functioning properly.
    I seem to remember this being a problem if you just put in LED bulbs. I would recommend getting the stock type bulbs and replace them at the nearest place to purchase them.
    I am here: http://tapatalk.com/map.php?z2salg
    Oct 2008
    Tupelo, Ms
    See if this thread helps any. It has to do with LED tail lights
    http://www.spyderlovers.com/forums/s...-Limp-Home-Fix
    Happy Spyder owner
    Mark
    Aug 2008
    PENSACOLA, FLORIDA
    1-985-876-7610[/QUOTE]
    Quote Originally Posted by napper39 View Post
    Will I further upset anything when removing fuses and relays to check. Is there a physical sign of damage to the relays or is it not visably detectable?
    St'09
    Aug 2008
    PENSACOLA, FLORIDA
    Lastly, before getting on the road. I've been using the LI1157RCZ. What is the standard brake light number? Can I get it at any auto parts store? Thanks again. You are an amazing family!
    St'09
    Mar 2008
    Allegan, MI
    I'm thinking that standard 1157 lights should work. Can somebody else confirm that, Lamont?
    The 1157s should do it. Both should be replaced.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Aug 2007
    Springfield, MO
    Most likely this will get him back on the road with no issues.
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by Farmboy View Post
    Actually that's not correct. HD's will drop down to running on one cylinder if they get too hot... their version of 'limp mode'... which would easily restrict the speed they can go.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Firefly View Post
    That's only in parade mode, ie; Setting at an idle in very hot temps. for extended periods. the rear cylinder will shut down to cool it, And then will turn back on as soon as you hit the throttle.
