Results 1 to 25 of 50
    GOS member (Girls On Spyders)
    Feb 2012
    Garland, TX
    Cool Original Grip Buddies
    The OEM grips on my RT-S SE5 basically suck.......my hands ached all the time. As the bike grips are heated and I didn't want to lose that, I searched high and low for options.
    A friend of mine turned me on to Original Grip Buddies which are made individually to fit all bike grips. They are made of neoprene and install in moments. They basically wrap around over the OEM grips.
    I did a 300+ mile ride with them and was amazed at the difference I felt. Hands didn't hurt, felt no fatigue and it actually reduced the small amount of vibration the bike produces.
    They are really reasonably priced. The designer holds 10 patents and was an absolute joy to chat with. I received them in just a few days.
    If you don't want those giant Kuryakyn clam shell grips (which were way to big for my hands) these grips are the way to go. I just can't say enough about how wonderful they feel. I'm going to the Republic Of Texas Motorcycle Rally in Austin, TX in June and these grips will make the ride much more enjoyable. Check them out!!!
    Sep 2007
    Mesa, AZ
    DITTO!
    Jan 2012
    Florida
    I am not familiar with the grips you write about, however they sound great. We purchased the oversized foam grips from Reggy at Tricled at Spyderfest and are very happy with the improved comfort. They were only $20 and well worth much more.
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Not sure if Grip Buddies are the same as Grip Puppies
    This thread was also about foam grips
    http://www.spyderlovers.com/forums/s...t=grip+puppies
    Eddie Sheppard
    Readng UK
    May 2012
    Saratoga springs, NY
    Quote Originally Posted by eddieshep999 View Post
    Eddie Sheppard
    Readng UK
    Hi Guys!
    My OGB's are definitely not Grip Puppies. See them HERE
    Best,
    Dave R.
    Feb 2012
    Portsmouth, Va.
    Quote Originally Posted by Adirondackjack View Post
    Hi Guys!
    Best,
    Dave R.
    I am going to give them a try, Order is in
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    I ordered at set. I hope they help with that aching feeling after along ride.
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    May 2012
    Quote Originally Posted by upsdoctor View Post
    upsdoctor-
    Got your order, and we'll most likely get them out today (Sunday). I think you will find these will help with the problem you described. Your description is exactly why I developed this product.
    Best,
    Dave R.
    May 2009
    Connecticut
    Hi Guys!
    Best,
    Dave R.
    I have Grip Puppies. Are these the same thickness?
    Can I take them off in the winter when I Put my Velcro Oxford Hot Hands on?
    I Just might try them!
    Sea Doo GTI-SE 90 Jet Ski!!
    May 2012
    Quote Originally Posted by Sarge707 View Post
    Sarge707-
    I will try to describe the differences:
    Puppies vs. OGB's
    Slip on (with some difficulty)/ Easy to install yourself in 5 min.
    Open cell foam rubber/ Closed cell neoprene with embossed
    rubber skin
    Absorb Water/ All-weather
    Not very effective at
    conveying heat through
    to your hands from heated grips/Heated grip compatible
    Gotta cut them to fit your bike/ delivered to you "ready to install"
    Modest Vibration damping/ Excellent vibration damping
    Look like black marshmallows/ Look OEM
    Approx. 3.9 mm thick/ 4.7mm thick
    Not sure if this helps, but I tried to give you the information we have.
    Best,
    Dave R.
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Default Original Grip Buddies
    Just ordered a set. Maybe they will help cure my right hand fatigue and tingling issue.
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    May 2009
    Connecticut
    Sarge707-
    Puppies vs. OGB's
    rubber skin
    Best,
    Dave R.
    Sounds excellent BUT can I take them off for the winter because the Oxford Hot Hands won,t fit with then on there.
    Can I re-use them next season or is the sticky for I use?
    Jan 2012
    Nashville TN
    I ordered mine from Reggy at TricLed when I ordered my brake pedal and fender lights. They are great!
    May 2012
    Sarge707-
    My answer to your question depends on how careful you are. I've had many customers either re-positiion them, or take them on an off multiple times, or move them from bike to bike. In every case they were super careful not to contaminate the sticky backing of the hook velcro. If you think you will want to move them and keep them aside for another use, simply keep the backing plastic and remember which side is to the sticky (because it matters). Also, the longer they are on the less likely you are to salvage the adhesive.
    I hope this helps.
    Best,
    Dave R.
    May 2012
    Quote Originally Posted by Chazzman View Post
    Chazzman-
    I would like to ascertain if you did receive my patented product, because I do not have a dealer named "Reggy at TricLed". I do exclusively manufacture and distribute my own grips, so please help me to determine this answer. Was the product a neoprene grip wrap attached with a sticky-backed piece of hook velcro sewn to one edge? And what was it called on the package?
    Thanks so much for your invaluable information.
    Best,
    Dave Reppert
    Founder
    Original Grip Buddies, LLC
    May 2009
    Connecticut
    Sarge707-
    I hope this helps.
    Best,
    Dave R.
    Thanks, They sound good and I can buy a New Pair Next Spring if I like them. Will order Monday!
    Oct 2007
    Just ordered mine too!!!
    Sep 2009
    Chelmsford, MA
    Me too! USA made, excellent materials, ingenious simple design, gotta love it.
    Jun 2010
    Maryville, TN
    Just ordered 2 sets for me & my wife's Spyder...Will be great if they work.
    Springfield, MO
    Chazzman-
    Best,
    Dave Reppert
    Founder
    Please respect our rules for vendors here. Thanks
    http://www.spyderlovers.com/forums/s...orting-Vendors
    Aug 2010
    Newberg, Or.
    I just ordered a set. I would suggest you become a vendor on SpyderLovers. It's a great venue for us after market manufacturers.
    Ride in comfort,
    John
    Seal FloorBoards
    May 2012
    Quote Originally Posted by Lamonster View Post
    I definitely respect your rules. Unfortunately, while your $50 per month is very fair, at $300-$500 per year, it is currently above the pay grade of such a new and small 1-man, USA-made startup company like mine.
    Regretfully, I will not be able to post or respond to posters who need clarification regarding information on my grips, in my efforts to respect the existing board rules. If my circumstances change, I will certainly come back and join as a vendor.
    Thanks to all,
    Dave R.
    Springfield, MO
    Thanks to all,
    Dave R.
    I appreciate that, thanks.
    By the way the guy that posted above you is a one man USA made startup company and he has done very well as a vendor here. Same with Spyderpops and a few more vendors so you can wait till you grow the company or you can take the risk and see if this site will help you grow the company, that's what they did.
    Active Member Dizneyman's Avatar
    Sep 2011
    Cocoa Beach, Florida
    Thanks to all,
    Dave R.
    Will be placing my order tomorrow!!
    May 2012
    Those are all great stories, and I understand from some here that you, yourself, manufacture and sell here on your own site so you can appreciate what working with a budget is like when you are trying to grow a small business like I am. It is important to crawl before you run, and simply throwing money at a problem is not always the most prudent approach. I appreciate your encouragement of my small business. BTW, if you ever bring back a program like I understand you had when this board was started, vendors were needed, and you wanted to encourage guys like me to become vendors by providing incentives or promotions, by all means contact me. also, I appreciate your understanding the 1-man USA company business model. We need much more of that in this country.
    Best,
    Dave R.
