Headlight Question
Both headlights and foglights are off. Is it possible that relay has blown even though there are no codes flashing?
Thanks
Mark
Mark "Spyderman" Adams
Thanks
Yup-- check relays and fuses... had this happen once.......can't recall which it was....
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
So, it turns out that the fuse box under the seat has a headlight fuse...
Mark
Blazing Member
Did it blow or was it just loose ?
Glad that you found it and are back up and lighting your way to more miles and smiles!
Motorbike Professor
Blown fuses (especially big ones) happen for a reason. I'd keep looking for a cause.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
It was blown... but in 4 1/2 years and 80,000 km's it's the 1st and only fuse I've blown. Have a spare one now and if it blows again... I'll have to troubleshoot.
Mark
