brake pad
Dr. Buck,
Name of vendor for the over size brake pad.
Thanks canam1
Originally Posted by canam1
Dr. Buck,
Thanks canam1
Scroll down to the bottom of the page.
http://tricled.com/TricLed.com/New_Items.html
2012 Spyder RT Limited
Guardian Bell (gift from son)
Spyderpops bumpskid
ISCI hand brake
BajaRon Anti-Sway Bar
BRP Adjustable Wind Deflectors
How did you modify the gps location to the dash? Can you describe or show a pic? I have mine (RAM mount) where the limited has its mount, but would like to move to dash where more easily seen. Thanks
Hope this is what you are looking for.
http://www.spyderlovers.com/forums/s...ght=dash+mount
2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
Originally Posted by ornerydog7
Yep, That's the process I followed. There is just enough slack in the wire harness going to the GPS to make it fit. I found it fairly easy to do after you cut all the wire ties off.
Love the Limiteds! Time for me to trade up!
Two more things you could do
There two more things. You could do!
Reflective pin striping
Paint the back section Pearl White
See how I did mine at www.wa4idi.org under Spyder
I like your idea on the Yeasu radio what antenna did you settle on?
MODS
Nicely done beautiful work and well thought out upgrades.
Bob I love your paint job on the back end. Looks very good. I may have to consider something like that. Was it done by an auto body shop? What type of paint was used?
The antenna I setteled on is a Diamond NR-73BNMO. It's half wave on 2 m and collinear on 440 and doesn't need a ground plane. I used the Diamond HRKS adhesive backed mount. I trimmed it down in size and used the 3M activator to help it stay stuck to the Spyder with a smaller surface area. So far ~500 miles and it isn't coming loose yet.
Digital Voltmeter Info request
DR Buck,
I love your install. I looked for a good looking dig VM but couldn't find one. I'd like to duplicate your install when I get my RT-S in a couple months.
What's the manufacturer and model number of your digital voltmeter and who did you purchase it from?
2013 Spyder RT-S SE5
Nickname: ULY ( Unusual Little Yellow, pronounced "ooo-lee")
> Custom Dynamics HMT LED Brake Lights, Dual Converter and Magic Strobe
> Kuryakyn 6183 ISO-Grips
> Battery Tender Jr.
I love the Oil Pressure Gauge & Volt Meter Mod. IS this an after market add-on that can be ordered?
If not is there a post somewhere with instructions on how to do it?
Thanks,
Bob
Time to trade it in and start all over
Just Kiddin
Cruzr Joe
Cat bypass with Stock Muffler
Dr Buck, I enjoyed meeting you at the BBQ. Thanks for letting me hear what my RTS SE5 will sound like with the Cat Bypass and stock muffler. Sounds great and with less heat. Thanks again. Richard
Flush Mount Turn Indicators
Hi,
Just wondering where you obtained the led indicators on your mirrors? I too have difficulty seeing the indicators in the dash.
Originally Posted by Aussy Joel
Hi,
TRICLED now makes a nice simple kit for the RT....
Originally Posted by DR Buck
Added a few more mods in recent weeks. The most significant was installing 2-way ham radio. The radio I installed was the Yeasu FTM-10R. It's a bluetooth capable dual band VHF/UHF radio designed for motorcycles and ATVs. I installed the main chassis in the frunk and the control head on the original GPS mount on the handlebars. The antenna was installed in the unused mounting position opposite the factory radio antenna.
I also installed a cup holder on the dash using RAM mount hardware. It works well, does not block gauges and does not swing when steering as it is not on the handle bars.
I will post pictures in the near future.
Waiting for picture and how you install the antenna I'm looking how I will install mind
Hi,
Got them at a local auto parts store. Only cost $6.99. Cheapest mod I've done.
After a few tries I found that only a 1/2 wave would work due to no ground plane. I used the Diamond HRKS stick on mount trimed down and stuck over the unused antenna mount location with the wire feeding into the opening. To make sure it stayed put I put some of the 3M tape activator on first. You can adjust the antenna angle to match the factory radio antenna.
I'm planning on adding a Yaesu FTM-10 to my RT-S also, what kind of antenna did you use? Looking at the rear of your bike I don't see any exposed antenna at all, or are you just using for it's bluetooth/am/fm?
Doc
Digital Oil Pressure Gauge & Volt Meter
Hey Dr... Where did you find the Digital Oil Pressure Gauge & Volt Meter? Once installed, Did your fuel gauge show up in the digital display window automatically or did you have to make some adjustments? Thanks, Reggie
