Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: Stubby Antenna
    Registered Users Chazzman's Avatar
    Jan 2012
    Nashville TN
    Default Stubby Antenna
    Where do you purchase the short antenna for the RT?
    'Bikeless'
    Active Member GLHRN's Avatar
    Jul 2011
    Mt. Juliet/Nashville, TN
    Custom Dynamics has a shortee antenna http://www.customdynamics.com/can_am_spyder_antenna.htm
    I have been thinking about changing mine as well. Will be interested to see if there are any other short antenna recommendations and also will it work for CB as well. It claims it does??!!
    Also, looks like ESI (a site sponsor) also sells them.
    Very Active Member cjackg's Avatar
    Chattanooga TN
    Walmart sells a Scosche black rubber stubby antenna for about $8 and includes several adapters. Several RT owners have used this this one and it works great.
    FYI... I tried the Custom Dynamics Shortee; it didn't work as well as the OEM here in our mountains...
    And I hate like to have to say that! Maybe out on the Plains it'd do a better job...
    Dec 2011
    Baltimore Ohio
    My OEM antenna broke off going to Cuba and picked up an aftermarket from auto parts store there with all the adapters it was not working well. Had to buy two bolts 6 mm would screw in the base and the antenna with no trouble, but had to cut the heads off and weld the heads together works great but the short antenna had to go for it could not draw the stations as good. Used a same length as OEM but stainless steel and had great pick up. I had lost the station in the hills of Ohio and with this short one, new OEM length Stainless antenna it has worked just fine.
    Quote Originally Posted by Chazzman View Post
    The stubby antenna from Walmart worked well for me when the OEM fell off. Since my dealer fixed it properly, I have an OEM back on the RT. The price was right at about $10.00. (higher in AK ?).
    Jan 2012
    Nashville TN
    Guess I will stay with the OEM that is currently installed. Thanks
    'Bikeless'
    Dec 2011
    Default Bob T
    My son bought a stubby antenna on E-Bay for 3or4 dollars. its about 3" long it doesn't work quite as well as the original but I like it better
    Active Member anthony422's Avatar
    Aug 2013
    Mahopac,NY
    Thumbs down
    don't waste your money on the wall mart antenna you get half the reception thats a fact
    Mar 2008
    Allegan, MI
    Quote Originally Posted by anthony422 View Post
    Did you use LOctite on it? That will reduce your reception unless you are very careful to use only a single small drop on the very last thread. For most the Walmart Shortee has increased reception.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by NancysToy View Post
    I agree, when I swapped ours out for the WalMart one I put just a small amount at the based of the threads. Wife hasnt complained about the reception which tells me that is as good or better than the OEM antenna.
    Sent from my SCH-I545 using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    I uses stubby antenna from stubby antenna.com. The reception is about 5 miles less. At less 70 miles of reception.
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Invalid Emails
    Aug 2013
    Warwick NY
    Doesn't any one own a iPod ?
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I installed the wall Mart shortly I get more station's than the oem, $8 works great I use Pandora for my music its free on smart phones
    Bryant, Arkansas
    Quote Originally Posted by cjackg View Post
    Cruzr Joe
    Bryant, Arkansas
    Worked fine on mine.
    Cruzr Joe
    Bryant, Arkansas
    Quote Originally Posted by Mt-man View Post
    Very seldom listen to radio, ipod has all my music on it.
    I use the radio only on occasion
    Cruzr Joe
    Oct 2011
    Jacksonville,Ar
    I use the IPod when not in local area.
    15 rt , yes Black
    Registered Users Flash Gordon's Avatar
    Feb 2013
    Central Florida
    I use a Sansa MP-3 most of the time. With 1,000 songs on a Radio card as well as about 1,000 I downloaded. I don't get tired of the variety.
    Active Member MidTNDawg's Avatar
    May 2012
    Palmyra, TN
    Default Does no one
    use the weather radio when on the road? It is a necessity for me.
    Doug Barnes
    James 4:17
    all on two wheels. More on four or more. Guess I may need to start multi-coloring for three wheels.
    I've got one of those little 8 Gb "Saltine crackers"...
    over 600 songs that just aren't fit for human consumption!
    I kind of bounce back and forth between it, and the FM stations that I can pull on the radio...
    Although we've got some XM radio in the works for 2014!
    Invalid Emails
    Dec 2013
    United Kingdom, North Wales
    Default Short aerial
    Just purchased my stumpy aerial and like I've said before once the winds blow them selves out I'll be fitting this one,
    of your products?
    Mar 2011
    gaines Michigan
    Quote Originally Posted by GLHRN View Post
    Good antenna.
    I tired theirs on my 2010 RT, and wasn't happy with the results...
    To be fair: I live in the Catskill mountains, and radio reception Is always a bit sketchy.
