Nope, it's right where it should be. I unhooked the trailer to lift the Spyder. You see a cap that's off but miss the big freaking fender I added. You really need to get out more
I saw the fender () but not the plastic teather and the cap...
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
Working on my knees at Cowtown doing the NBV installs put a hurt on me and I'm just now getting better. I decided it was high time I went ahead and sprung for a good lift. I spent a few hours looking at all the different models and wound up going with the Weaver W-1500. The RT is right at 1000 lbs and I don't like the idea of using a 1000lb lift on a 1000lb bike when I could get a 1500lb lift for a couple of hundred more.
I am going to have to make it a little wider but that shouldn't be a big deal. I'm looking forward to getting off my knees when I do oil changes and work on my Spyder and others. http://www.derekweaver.com/update/products.aspx?id=288 W-1500
Description
Weaver Lift's Popular model W-1500 offers 42" lifting height and comes complete with side extensions, front chopper extension, drop-out panel and vise. True Hydraulic Air/Oil operation provides for a very smooth operation. Free Shipping for a Limited Time! Restrictions may apply.IN STOCK
Direct Price:
$1,125.00
Free Shipping
buy now
question: I want one, however once they drop it on the street delivered, how did you get it into the garage? up hill grade. table is 500-800lbs
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020
thats ok, rented a fork lift to get it up drive way after delivery truck drops it with lift gate. owner of rentals will send a manual lift as well to position it after its in garage. Owner of rental co. told me he will make sure its put exactly where I want it...very nice man.
Thinking of a two post lift. Also good for auto/truck and you can stand under while working under. Yes I do have the room.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Here's some pics of my Black Widow motorcycle lift modification to lift my Spyder. Two 1" black pipes hold the wood extensions. I had to put the front extension on the lift to fit the Spyder. I open the tire jaw all the way and the Spyder rear tire fits in.
It looks like a sensor or a vent for whatever is above it. I haven't had my Spyder apart yet to recognize it. I do have the Shop Manual on a disk. i'll look it up for you. Sorry, I couldn't find it. Does your Spyder have Automatic AirBag and compressor? If it does, that piece might be the Pressure Relief Muffler. My best guess. Try lowering the Airbag pressure by the switch and listen for and feel if air is coming out of the thing-a-ma-jig.
I have a 4 post car lift with a jack lift and a scissor car lift. Advantage of getting a car scissor lift is you can work on your car tires brakes etc easier. A little more expense but a lot more useable. I just built a wooden table I put on the scissor lift. It makes a super work area also when I need a bigger table and when I don't need it I simple remover the top.
