Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    Springfield, MO
    Quote Originally Posted by docdoru View Post
    Nope, it's right where it should be. I unhooked the trailer to lift the Spyder. You see a cap that's off but miss the big freaking fender I added. You really need to get out more
  2. #27
    May 2008
    Clearwater, FL
    Quote Originally Posted by Lamonster View Post
    I saw the fender () but not the plastic teather and the cap...
  3. #28
    Springfield, MO
    http://www.spyderlovers.com/forums/s...r-plug-cap-mod
  4. #29
    May 2008
    Clearwater, FL
    Aug 2012
    Houston, TX
    Just checked on this and looks like they are still doing free shipping, so very cool.
    Course that means I need to make room for it...anybody in the H-town area want to buy a used HF m/c lift for cheep?
    Guess I'll be putting up a post in the FS forum cause if I don't get rid of this one first, the wife will be all and we don't want that.
  6. #31
    Phoenix
    Default install of lift
    Working on my knees at Cowtown doing the NBV installs put a hurt on me and I'm just now getting better. I decided it was high time I went ahead and sprung for a good lift. I spent a few hours looking at all the different models and wound up going with the Weaver W-1500. The RT is right at 1000 lbs and I don't like the idea of using a 1000lb lift on a 1000lb bike when I could get a 1500lb lift for a couple of hundred more.
    I am going to have to make it a little wider but that shouldn't be a big deal. I'm looking forward to getting off my knees when I do oil changes and work on my Spyder and others.
    http://www.derekweaver.com/update/products.aspx?id=288
    W-1500
    Description
    Weaver Lift's Popular model W-1500 offers 42" lifting height and comes complete with side extensions, front chopper extension, drop-out panel and vise. True Hydraulic Air/Oil operation provides for a very smooth operation. Free Shipping for a Limited Time! Restrictions may apply. IN STOCK
    Direct Price:
    $1,125.00
    Free Shipping
    buy now
    question: I want one, however once they drop it on the street delivered, how did you get it into the garage? up hill grade. table is 500-800lbs
  7. #32
    Faribault, MN
    3 more friends....
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  8. #33
    Jun 2014
    ny
    I would expect pallet jack or a few dolley's
  9. #34
    Phoenix
    Default resolved
    Quote Originally Posted by marty1096 View Post
    thats ok, rented a fork lift to get it up drive way after delivery truck drops it with lift gate. owner of rentals will send a manual lift as well to position it after its in garage. Owner of rental co. told me he will make sure its put exactly where I want it...very nice man.
  10. #35
    Sep 2007
    Rome, WI and Mayfield, KY
    Default Lift table
    I unloaded my direct lift table on to a small utility trailer from the semi. Then pulled that into my driveway and backed in to my shop.
    Lucky
    2015 RTS SE6
    2008 Harley Ultra
    1999 BMW R1200C
    1986 Harley Electraglide
  11. #36
    Nov 2013
    Oro Valley Arizona
    Thinking of a two post lift. Also good for auto/truck and you can stand under while working under. Yes I do have the room.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  12. #37
    Sep 2018
    Lebanon, Pa.
    Default Motorcylce lift mod
    Here's some pics of my Black Widow motorcycle lift modification to lift my Spyder. Two 1" black pipes hold the wood extensions. I had to put the front extension on the lift to fit the Spyder. I open the tire jaw all the way and the Spyder rear tire fits in.
  13. #38
    Nov 2018
    Claremore, Ok.
    It looks like a sensor or a vent for whatever is above it. I haven't had my Spyder apart yet to recognize it. I do have the Shop Manual on a disk. i'll look it up for you. Sorry, I couldn't find it. Does your Spyder have Automatic AirBag and compressor? If it does, that piece might be the Pressure Relief Muffler. My best guess. Try lowering the Airbag pressure by the switch and listen for and feel if air is coming out of the thing-a-ma-jig.
  14. #39
    Apr 2018
    ontario
    I have a 4 post car lift with a jack lift and a scissor car lift. Advantage of getting a car scissor lift is you can work on your car tires brakes etc easier. A little more expense but a lot more useable. I just built a wooden table I put on the scissor lift. It makes a super work area also when I need a bigger table and when I don't need it I simple remover the top.
