I have never had difficulty with a drain plug on three Spyders over many oil changes. A standard 3/8" drive ratchet with a hex socket loosens them every time with no more than a grunt. I always use a torque wrench to tighten them, and replace the copper washers when damaged...or periodically anyway. I see nothing wrong with the design if the proper tools are used and the plugs are loosened and tightened properly. The footboards weren't BRP's fault, BTW. They could hardly design with the aftermarket in mind.
Add to that, a short "cheater pipe", aka, and old spark plug socket. The plugs will release without needing the grunt.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
