Page 1 of 2 12 LastLast
Results 1 to 25 of 49
    Nov 2008
    las vegas, nv
    Default Motorcycle oil at Walmart and amsoil
    Now that mobil1 is no longer suitable for spyder, castroll oil sold at Walmart is still good, right?
    Also, is amsoil carried by any retailer at all?
    I know someone here sells them, may be Ron who I get filters from, but I like to be able to but them when I am not in my home area.
    MLM turns me off but if it's that good, I was willing to try. Are their published comparison done by a 3rd party?
    6 states down 42 states to go
    Chattanooga TN
    Castrol RS 4T Full Syn motorcycle oil is not usually available at Walmart but you can buy it at most Advanced Auto Parts or at Cycle Gear.
    Branson, Mo
    Walmart in my area sells Valvoline Synthetic 10-40 for motorcycles, which I run in the wife's 08 RS. As I remember on Amsoil's test resut charts is rated just a few spots below Amsoil. Walmart also sells Mobil Synthetic 10-40 for motorcycles. Don't remember the name right off but not the same as Mobil 1.
    Sep 2009
    msla mt
    LOL!! Didn't hear about the Mobil 1 fairy tale. 20-50 ,all i've ever put in the.or as far as that goes in any of my motorcycles. 02 kaw mean streak,02kaw zx-14, 02hd ultra, 09 kaw 650klr, o8 rs se5. won't consider another brand or weight
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by madjack View Post
    Running 20W-50 in an engine designed for 5W-40 is just asking for trouble.
    Sep 2009
    msla mt
    Sorry professor, but "asking for trouble" is a little to vague.
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Default little to vague
    I also have used Mobile1 4T Syn 10-40 from my first Spyder ,, 08 PE GS and now in my 10 RTs..
    Got caught up in the hype on Amsoil and gave it a try....did not hold up to hype...I won't go into details here
    but did not perform up to my standards...both Spyders are manual shift now I'm back to Mobile 1...
    Freebob...
    Nov 2008
    las vegas, nv
    Quote Originally Posted by freebob View Post
    Freebob...
    I been using mobil1 for the convenience but wasn't there a thread about mobil1 being changed?
    I've seen some walmarts carrying castroll so I was gonna go with that unless amsoil was worth the trouble...
    Please do go into details.
    May 2009
    Connecticut
    I switched to Amsoil after using Mobil1 4T and then Castrol 4T RS when the Mobil 1 API changed.
    Use Amsoil now and have 12 more quarts in a box so it better be good!!!
    Sea Doo GTI-SE 90 Jet Ski!!
    Jul 2011
    PA
    Default Mobil 1 Motorcycle Oil
    Mobil 1 Racing 4T 10W-40 motorcycle oil. I think BRP is missing the boat on this oil due to their unfamiliarity with the motorcycle world. Mobil 1 motorcycle oil does indeed meet API spec SM which BRP states should not be used and will cause clutch slippage. However, Mobil 1 motorcycle oil also meets JASO MA which is the holy grail as far as wet clutch performance is concerned. If you own a Honda motorcycle, for example, they specify that the oil must meet JASO MA. That pretty much excludes any regular automotive oil and is a way of specifying that it must be motorcycle oil that has been tested for wet clutch performance. I think BRP is unaware of this spec since they don't live in the motorcycle world. Their concern over API SM is likely based on automotive oils meeting API SM specs which would also state "energy conserving" in the API seal on the bottle. Honda prohibits using any oil with an API "energy conserving" seal on it -- they are too "slippery" for long-lived wet clutch performance. All high-quality automotive oils, even pre-SM oils like SJ or SL had the "energy conserving" seal on them. So according to BRP, you could use one of those automotive oils (SJ or SL energy conserving) and meet their spec while being totally outside Honda's spec. I personally think that is incorrect thinking on their part and what they should be doing is copying Honda and other motorcycle manufacturers. They should be specifying motorcycle oil meeting JASO MA and prohibiting API "energy conserving" in order to assure good wet clutch performance. API SM is not the problem in and of itself. If you look on your Amsoil bottles, Amsoil meets JASO MA and has an API SL rating, not stating "energy conserving". Mobil 1 4T meets JASO MA and has an API SM rating and is not "energy conserving". If you look at automotive oils, you will not find them tested against JASO MA and you will find the better ones to be "energy conserving". Personal anecdotes on oil are highly unreliable in my opinion but I will offer one anyway. I've used predominately Mobil 1 4T, and occasionally Amsoil, in every motorcycle I've owned and had excellent performance. For example, 95,000 miles on a Gold Wing which is a big heavy motorcycle that demands a lot out of a clutch, and not a trace of slippage. That said, you go against BRP recommendations at your own risk.
    RT and Gold Wing States & Provinces
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Engine clearances and oil pumps, oil passages, etc., are designed for a particular oil viscosity. Increasing the warm weather viscosity from 40 to 50 weight can increase oil pressure beyond tolerable limits, and actually inhibit oil flow under some conditions. It can also cause physical damage as close tolerance parts literally are forced apart under pressure, or starve plain bearing surfaces such as the camshaft bearings when the thicker oil can't flow as readily to them. Increasing the cold weather viscosity from 5 to 20 is a much larger jump, and can similar, but more devastating effects on a cold engine in cold weather, even starving the oiling system and damaging bearings, as well as causing serious wet clutch issues and transmission problems.
    Feb 2012
    Miami - Aventura FL
    Quote Originally Posted by Sarge707 View Post
    Amsoil is the way to go!!!
    Feb 2012
    Portsmouth, Va.
    All I know is that if you have a oil related problem that damages your engine AmsOil will cover the cost of repair. I have a case of AmsOil and changed to it at the 600 mile change.I am using the motor cycle oil in 10w40. And I will continue to use it as long as I own a
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    I use the BRP full synthetic and not worry about it.
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by MarkLawson View Post
    I did too..... Until they stopped selling it. Now it's all a blend---- not full syn and no weights listed.... Just 'summer blend'. Uggggg
    Now running amsoil and seems fine.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    BRP has a full synthetic again, but I couldn't find a viscosity rating on the jug.
    john
    Invalid Emails
    Dec 2007
    winnipeg mb
    Anyone tried Mobil 1 5W-40 synthetic diesel? I used it a few years ago with no problems but went back to BRP's synthetic blend for now.
    Jun 2010
    Las Vegas
    Quote Originally Posted by aka1004 View Post
    In Michigan we could buy Amsoil at our Auto Value Parts store. We have an Amsoil distributor here in Las Vegas that I buy from.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2008
    Vail, AZ
    The Suzuki SV 1k and 650 ran great on Rotella "T", I think a few people tried it on their Spyder and it developed a clutch slip. I believe it did return to normal performance with a return to motorcycle oil.
    Quote Originally Posted by spyryder View Post
    2009 GS SM5 , Red/Black
    Very Active Member mastertek2000's Avatar
    Mar 2012
    E Freetown MA
    i will be doing my first service my self i am a automotive master technician so i will use can am factory stuff for the first time
    but after that am soil is the only way i have been selling am soil for the longest time and is all i run on all my bike never had a problem
    Feb 2012
    Portsmouth, Va.
    Quote Originally Posted by mastertek2000 View Post
    I went with Amsoil right from the start. It took me about 2 hours to do my 1st oil change. I can most likely cut that time in half next time. I only had 2 screws left over.
    I think that discussing oil brands might even be more fun than tire brands or cleaning products...
    Spyderless Member
    Dec 2008
    north/central n.j.
    Your slipping, You for got octane wars, Of 08-09-10-11-12.
    Sep 2009
    msla mt
    Whats the first thing to do when you start to market a engine oil. Oh yea," we'll replace your engine if the oil causes failure," what a joke. In my 35+ years of engine repairing & biulding, I have never seen a case where a paticuler brand, or viscosity could ever be blamed for a failure. Human neglect, abuse, incompetence you bet, parts failure from manufscture defect, fatigue, improper application, many times. But NEVER because of the oil being used.
    Jul 2011
    Mitchell, Ontario, Canada
    Default agree with most not all
    Quote Originally Posted by gypsy_100 View Post
    The JASO MA spec has been replace by JASO MA1 & MA2 this is because Japanese motorcyle manufactures still had problems with excessive clutch slippage with the original spec. So the specification has been split in two with MA2 with better clutch slippage preformace. I am not sure why BRP singled out the SM rating and not SJ & SL but it may have to do with the requirements for lower ash content for SM which is achieved by reducing the amount of detergent added. The reduced ash content was implimented to prevent damage to the catalytic converter.
    2018 F3 LIMITED
