So I went out to an empty parking lot to practice backing up with the trailer on . . . slowly I went backwards, using the side mirrors and the trailer goes left. I straighten up, try again and same results . . . . over and over again.
With all the lots going to be full at Spyderfest I really need to figure this out before I get down there. We can't leave the trailer at the motel since it carries my wife's mobility scooter.
Anyone have the trick/secret to backing this thing up at least enough to get out of a parking spot? Any and all help appreciated . . .
I agree the RT622 is a bear to reverse with. I try and parallel park whenever I can or drive into the parking spot. Then when I backout I Drive away the opposite direction to the way the RT trailer jackknifed.
Keep practicing...and go slow! Most of us have trouble, and avoid pull-in parking when we can. I turn around instead of using the mirrors, when possible. I have found it easier to back into the parking place when possible. The secret to this, and backing any trailer, is to correct as soon as possible, and stop and pull ahead the first second things start to go bad. You'll get the hang of it, I promise.
Backing up these little trailers is a bit of a pain in the you know what. I have pulled a lot of trailers over the last 25 years from 53 foot right down to my little Aluma bike trailer and the smaller they are the easier it is to jack knife them. The trick is very slow speed with a little trailer and very slight adjustments to the steering. If you want the trailer to go left you will have to turn right slightly and if you want to turn left than adjust accordingly. It does take practice but more importantly just be patient, very slight turns in the handle bars and slow speed. Watch the mirrors and make sure they are adjusted properly this will help as well. Good luck and practice lots hope this helps again very slow speed and slight adjutments
I still have some trouble at times backing up the trailer. A small steering correction makes a big change in the direction of the trailer. Take it slow and try not to become frustrated(I know,I know, that is what I tell myself). Short trailers are hard to back up, the longer the trailer the easier it is to back up.
The easy way to do back the trailer in, is aim for a parking spot. Back up slowly till the trailer starts wandering. Have your Dearly Beloved (Hubby) heft the trailer back into the middle of the parking spot, repeat the above until parked to your satisfaction.
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
I now am able to backup like I know what I'm doing! I used to drive around looking for pull through spaces and then I saw a friend pull into parking places with his trailer. I said Butch you're pretty brave doing that and he told me that it is much easier to back out of a place then it is to back into one. So I gave it a try and by God he's right. I find the trick to keeping it straight is to use the mirrors and to make slight movements left and right. Also be sure that you are in a straight line with the trailer before you begin to back up or you'll get screwed up.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
The above advice & suggestions are all very good, especially practice & patience
Back in 2010, we had our black RT-S & we also had the matching RT-622 Trailer & that thing handled like a dream & if BRP made a camper option for it, I wouldn't have gotten rid of it when we traded, but we needed a camper & couldn't afford both sometimes reality sucks so we now have our Moto-Mate camper & even tho it doesn't handle as well as the RT-622 it is much easier to back in & park, I think, like so many others have stated, cause its a little longer than the BRP trailer. I personally didn't realize this until we made a 450 mile road-trip a couple months back to ThreeFeets house to deliver her newly addopted cat She had a 3 or 4 car garage with one open bay for us to back into & she commented that she was impressed with how well I was able to back it right in. She said there was no way she could do that well with her RT-622 & I was kind of surprised, but she mentioned the length probably made our camper a little easier, as it is 11' in overall length including the tongue.
As you've read, there's no right or wrong way to learn this, to each their own & you have to find what works BEST for you. Personally, I look back as opposed to using my mirrors. One thing that comes to mind, was something I learned in my MSF class, about when taking a corner on a 2wheeler, don't watch where you are, but more of watch where your going. Of course, backing up with a trailer, you have to do both, but I found when I stuggle, its cause I'm usually paying attention to where the trailer IS more so than where I want it to go, if that makes any sense. Patience & practice, find what works for you & Good Luck. Teddy & I hope to meet ya at SpyderFest
I'm so glad to read all of these posts. Not so much for the 'how-to' but SO MUCH for the fact that I'm not alone!!! Facts are that a lot of us will be vying for all the PTP (pull through parking) spots . I have backed many a u-haul trailer, but for some reason, the 622 is harder. A lot harder. Likely it has something to do with the length of the tongue and the single point pivot (rear tire). Knowing that and still getting it wrong so many times..... Aaaaarrrrgh!!
So if you see me lifting the trailer to move it in line..... Now you know
Phil, Tyler TX- from my iPad3.5 using Tapatalk HD
____________________________ Phil - Tyler Texas 2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
With a trailer, it can be kind of tricky. Use just a small amount of steering. A lot of problems are simply due to either the person steering in the wrong direction or over steering or both. Sometimes it helps if you simply look over your shoulder and not use the mirrors.
Doing it with the spyder is a waste of time.....Rando nailed it and I totally agree....Dis-connect and do by hand....I have a a four stroke, two person snowmobile that weighs 750 lbs....the trailer weighs 275lbs...that's 900 lbs... I can move that by hand and I'm 65 ....life is too short to waste it parking or un-parking trailers ......unless you are doing it competitively for prize money....IMHO.....Mike....
Way back when I had a 1/2 ton truck and a 10 ft long trailer that I consistantly jack knifed without even blinking. Then my dad told me to put my hands at the BOTTOM of the steering wheel the direction you want the trailer to go your thumbs should point in that direction. That was GREAT advice and i could back up that trailer and then my 33 ft RV without a lot of hassel. BUT the spyder isn't equiped with a steering wheel!!!!! So I look in mirrors (old habbit) and put my hands UNDER the handle bars, so far it's worked fairly well, but that's me and I'm weired anyway. AND DO IT ALL SLOWLY!!!!
Like that will ever happen! I know my place and I stay in it after all these years. It's safe . . .
Papa
Lots of good advice here. In our case, we've been towing horse trailers for years on all types of vehicles and have learned that the longer the trailer (and tongue) the easier it is to back up.
Since the RT 622 doesn't make the grade that way it takes some time but it can be done and done well.
It seems to me that it is much easier to back up without using the mirrors.. small corrections can be made better by watching where you are heading rather than watching the trailer. Try to get the trailer in your peripheral vision so you are conscious of where it is heading and make the small corrections (remember left is right and right is left) as you go SLOWLY.
Good luck.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
This would be great if someone did a how to video on backing up.
When I first started learning, I did a google search and there were
videos on how to back up a trailer, but come to think of it they
were all big trailers, so it was easy for them I guess from reading
all the advice here. It takes me 3 tries or more to back into my garage
I would sign up for lessons at spyderfest if they were offered. Also watching
someone do it as they narrate it would be great too. As it is now
whenever I pull into a gas station I make sure i don't get trapped
