Results 1 to 24 of 24
    Very Active Member SpyderGirl's Avatar
    Feb 2008
    South Jordan, UT (Salt Lake)
    Default Front Wheel Bearings
    I have reasons to believe that the front wheel bearings on my 2008 RS are finally out after 43K miles. They wore out before my original front tires did!!
    Anyway, I was wondering who here has changed their front wheel bearings and how difficult was the process? It's got to be easier than the rear wheel and hub bearings
    Also, I was curious on the pricing I was quoted from the dealer for the parts... $48.22 each. They are more expensive than the front tires.
    Thoughts? Input? Suggestions?
    We are a happy THREE Spyder family!
    My Rides: 2008 Quantum Blue Premier Edition Spyder GS SM5 (#1344)
    2015 Pearl White / Red Can-Am Spyder F3-S SM6
    2016 Intense Pearl Red Can-Am Spyder F3-T SE6
    2019 Chevrolet Volt (ER-EV)
    2003 Jeep Wrangler Sport X 4.0L I-6
    RETIRED Owner / Event Coordinator - Annual Western Regional Can-Am Spyder Rallies
    Spyders in the Redwoods and Red Rock Spyder Rally of Southern Utah
    The West Coast's Can-Am Spyder Community Ambassador
    2008 GS , ISCI Quantum Blue
    Feb 2008
    Has no one here replaced their front bearings on their own yet? I am surprised that at 43K mine are gone, but they are definitely gone, I can tell by the noise they are making. I've got the shop manual, and it looks fairly straightforward, but I always like to ask people that have done it in the real world.
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by SpyderGirl View Post
    It seems like you'll be the first, I can't recall a post about that, Maybe some one will chime in.
    Mar 2008
    Allegan, MI
    I don't remember any.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Very Active Member WackyDan's Avatar
    Apr 2009
    Charlotte, NC
    I kinda remember only one other needing to do the fronts.
    WackyDan - Fun, not crazy.
    Charlotte (Matthews), NC
    Silver Moon SM5 - V35 and V46 Givis, CHAD, Motolight 35w steering lights, Dash Powerlets, Helibar risers, Garage door opener, Eastern Beaver PC-8, Digital voltmeter, Kewl Metal Intake, Evoluzione Sway Bar, RT Shocks and Juice Box PRO.
    *Mower deck in development*
    2008 model -new in crate, April 09
    26,000 miles.
    Looking for other Charlotte area riders to cruise with and compare Spyders.
    HAPPY SPYDER OWNER
    Aug 2007
    Springfield, MO
    I replaced the a front hub and the bearings need to be pressed in.
    Active Member cougar's Avatar
    Alpharetta, GA
    Time to trade it in on a new Spyder.
    Feb 2008
    Thanks Lamont. I saw that in my book too. I guess I'll be calling the shop.
    I guess my next question is, is 40k miles a bit early for these to be worn out? I wouldn't have thought my front tires would have out lasted the bearings.
    I've done hub and bearing assembly changes on a couple cars, but they had over 100k miles.
    Thoughts?
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    I don't recall this being done-- for sure not been done by many. The rear might actually be the easier of the two to do. Are you sure they're bad? Maybe you're hearing some break rub noise instead? Many of us that ride a ton (and really hard) have yet to need to replace them.... so I would find this uncommon.
    Let us know what you find out for sure.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Feb 2008
    Quote Originally Posted by Firefly View Post
    I'm not 100% sure, but pretty certain that it is the bearings. I know our isn't the brakes. It's going in on the 17th to have three bearings done. I should know for sure by then.
    Active Member zbunker's Avatar
    Dec 2011
    Altamonte Spgs, FL
    Your question got me looking through my 2012 RT 'Operator's Handbook.' In there it mentions that " Every 12K miles or every 2 years " the dealer is supposed to take a 'peek' at the front wheel bearings. I guess at 43k the bearings must have turned to powder
    Good luck with your new project.
    Ron
    Feb 2008
    Quote Originally Posted by zbunker View Post
    Ron
    Ended up not needing the bearings after all. I think I just need an alignment.
    May 2009
    Connecticut
    Toooooooooooo Good for you!!!!
    Sea Doo GTI-SE 90 Jet Ski!!
    Dec 2011
    Altamonte Spgs, FL
    Smile Wheel bearings
    At 43k on the bearings, if you haven't done so already, it may not be a bad idea to inspect and squirt some grease on them.
    Ron
    Feb 2008
    Ron
    The dealer will be taking care of that.
    Mar 2013
    Canada
    Good evening,
    Is there an easy way of checking if my left front bearing need replacement.
    At this point I am only assuming that it need to be replaced, but the mileage is only about 8000 miles.
    But there is squeeking and wheel woble, from that wheel.
    Or would repacking be sufficient.
    Thanks
    Dom
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by poordom View Post
    Good evening,
    Thanks
    Dom
    The front wheel bearing are sealed and cannot be adjust or greased, only replaced. Failure at 8,000 miles is rare but not unheard of. Take it to your dealer for warranty repair.
    2018 F3 LIMITED
    May 2013
    Stanton, ca
    Jerbear had his fail recently. He said he could tell they were a problem as you could grab the wheel and it would wobble on the axel. Just be sure it's not your ball joints that are loose! There was a recall on 2013's for that issue last year.
    Bob
    2011 RT-S SM5 - Black
    Jul 2011
    Quote Originally Posted by finless View Post
    Bob
    I don't think bad ball joints match his described problems.
    2018 F3 LIMITED
    Very Active Member freebob's Avatar
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Default wheel bearings
    Front wheel bearings are much easier to replace....Replacement bearings are easy to find at your local auto store..
    NSK 30bwd07
    Kml 633313c
    SKF ba2b633313c
    are all replacement bearings for OEM Bearings at at least half the price...and Maybe more online....
    Freebob...
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    It did on my 08 GS. I thought it was a wheel bearing and bought a replacement. As I was preparing for the installation it was then that I noticed it was 2 bad ball joints, not just one, so it fooled me. One was the upper ball joint and the other was on the tie rod. I never did do the wheel bearing, but it looks like a nightmare requiring speciality tools.
    Mar 2013
    Canada
    Thanks guys for your response.
    Dom
    Registered Users ChasingWind's Avatar
    Jun 2012
    Tacoma WA
    The front bearing are compressed in -& out I took the a arms to a machine shop with new bearing and had them do it. This is a whole day project
    Mar 2016
    Astoria, Oregon
    Default 2015 RT-S
    I have the squeak in the front end at about 30-35 mph. Gets louder the faster I go. No wobble, just noise. 16,000 miles, but I'm also 100 miles from the closest dealer.....
